HP’s intake inquiry ?
Yeah this is basically a do what makes you happy but don't confuse it with actual power gains thread. The afe dyno run was not back to back with a pretty huge ambient temperature difference between the two runs favoring the afe heavily. Definitely an extremely biased and, in my opinion, invalid test. An intake change is something that is so simple why not just run the two dyno runs back to back like 15 mins apart instead of waiting a whole week for the temperatures to drop to run again. I bet you they did run it back to back same day and saw literally 0 change and decided to wait for cooler temps to run again to get a result that they wanted to present.
Our cars and many modern cars already essentially come from the factory with a cold air intake. They draw the cool air from outside and have their own compartment separated from the engine bay compartment. Only way you are going to get more performance is if you can get more airflow either through a larger filter surface area (factory filter already pretty large) or being less restrictive and allowing more dust and air to flow through. But even then you aren't getting any more fuel into the combustion chamber because the ECU will control that and the air coming in isn't any colder so not any more dense.
CAKETOWN (01-07-21)
I don’t think that these intakes are pulling colder air, in fact they may be pulling slightly warmer air due to being more open than stock. But what I think what they are doing is making a straighter smoother path for the air to get into the engine. Turbulence is a huge factor in fluid dynamics. That’s I think why a lot of people talk about throttle response. When you hit the peddle, the initial in rush of air will get inside the engine faster if the flow is less turbulent and/or less restricted.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
