Used Oil Mistake
Hi all,
I changed my oil on my 2016 GS200t this past weekend. Since its impossible to fill up the cartridge filter with oil before the first start-up, I usually drive the car for a few minutes, then after it cools, add a bit to get the dipstick on the mark to account for the oil filter capacity.
I was extremely distracted while adding that last bit and I accidentally poured some of the the drained used oil (about an 1/8 of a quart) into the crankcase. I had it set in the same spot in the same container as the new oil, a stupid mistake. The oil was changed well before the 10,000 mile interval but it was getting to be a year old and I wanted a fresh batch and filter.
Would you change the oil again after that mix-up, both the oil and filter, or do nothing with that small amount? I have both the new filter and cartridge on hand since my NX has the same engine, I bought in bulk.
Thanks!
Thanks!
I would not worry about an eighth of a quart. No big deal.
You're totally fine. I wouldn't worry one bit at all about that. Even if you poured an entire quart of your old oil back in I wouldn't worry. I'd probably just change it a little earlier. I usually go around 7-9K on Mobil 1 EP. Even if it was an entire quart at least 80% of the oil will be new oil.
ECL (01-05-21)
ECL (01-05-21)
Wouldn’t worry about it. Change it again when you have time for peace of mind.
ECL (01-05-21)
Agree with all of the above - If I did my math right, based on the 200t capacity I was able to find online (4.9L / 5.2Q), an 1/8 of a quart would be 2.4% of the total oil volume. I wouldn't be surprised if there was still that much oil sitting around in the rest of the system.
ECL (01-05-21)
ECL (01-05-21)
Hi all,
Thanks!
Thanks!
An oil change is not a complete fluid flush and fill. There is still at least a pint of old oil left in the heads, timing chains and clinging to the inside of the engine. A 1/8 of a quart is only 4 ounces so you didn't hurt it. The main idea with an oil change is to get a new filter on it and to replace the used up additive packages in the oil with fresh additives.
Yeah, u should be fine man but if u can't eat or sleep at night, just change the whole thing again.
Not sure what you were going on about re the oil filter.
Your manual will state 2 volumes, with and without the filter.
This is not for your car an exampleCrankcase Service Refill Capacity: 6.3* Litres (Includes Oil Filter)
