Any DIY how to change front brakes on 17 GS350 AWD?
Old 01-10-21 | 02:49 PM
WBenz's Avatar
WBenz
Default Any DIY how to change front brakes on 17 GS350 AWD?
Hi there ..
Any DIY how to change front brakes on 17 GS350 AWD ?
could not find the thread ?
Old 01-10-21 | 03:13 PM
peasodos's Avatar
peasodos
Its the same as any 4GS
https://www.youtube.com/results?sear...gs+front+brake
WBenz (01-10-21)
Old 01-10-21 | 03:19 PM
WBenz's Avatar
WBenz
Thank you!
Does Lexus have a brake pad sensor ? I have a grinding sound coming from front ..
just wonder ? Any warning light , that says your brake are worn ?
Old 01-10-21 | 03:21 PM
peasodos's Avatar
peasodos
Originally Posted by WBenz
Thank you!
No sensor or warning you just have to inspect it.
Old 01-10-21 | 03:27 PM
eddie420's Avatar
eddie420
Hi there ..
From our own member @DIYDanCars
The following 2 users liked this post by eddie420:
RA051823 (03-19-22), WBenz (01-10-21)
Old 01-10-21 | 03:38 PM
WBenz's Avatar
WBenz
Thank you very much !
yeah.. hmm no sensors..
Old 01-10-21 | 03:43 PM
peasodos's Avatar
peasodos
IMO it's better that way. No expensive sensor that could fail/replace, parts are less expensive. The pads have the metal wear indicator, so it will squeak when you reach that point, That's when you know you really should change it. I can just stick my finger in between the pad and rotor and feel how much is left or if I'm really stretching it out, take the wheel off and inspect with a flashlight.
Old 01-10-21 | 03:53 PM
WBenz's Avatar
WBenz
Yeah.. just saying..I had 95' Mercedes E420 that had a sensor ...it was nice feature...that gave me a warning light..that brake are worn..
agree that parts are less expensive..
Thank you guys..😄
Old 01-11-21 | 09:44 PM
WBenz's Avatar
WBenz
Hey. End up i brought car to a Dealer .. they replaced rotors and brake pads .. and lug nut key with regular bolts. Because some shop lost our key from lug nut..
528$ total job.. not bad .
Old 01-11-21 | 09:47 PM
WBenz's Avatar
WBenz
But I confused they put a Rotors with part numbers is 43512-30350
while for Gs Fsport part number for rotors is
43512-30371
I am confused...
Old 01-12-21 | 06:54 AM
er34's Avatar
er34
43512-30371
I am confused...
The 30371 is for RWD F-sport which has 2 piece rotors.
Since you have the AWD F-sport, you want the first one.
Old 01-12-21 | 11:02 AM
WBenz's Avatar
WBenz
Thank you ..
Where to get correct parts numbers?
because this Lexus OEM website does not have correct part number. It showing without fsport or with fsport but 2wd
but I have Fsport awd!?
Old 01-12-21 | 11:24 AM
er34's Avatar
er34
Thank you ..
Fsport AWD has the exact same brakes as the "base" model
FSport 2wd is the RWD - which is the only one with the 2-piece rotors.
Old 01-12-21 | 11:30 AM
AJLex19's Avatar
AJLex19
Thank you ..
The same rotor (13.1" rotor part # 43512-30351 or 43512-30350) is used for the following models:
AWD non F-sport (base, premium, lux pkgs)
RWD non F-sport (base, premium, lux pkgs)
AWD F-Sport models (your car falls into this category)
The other rotor you mentioned is a larger 14.1" rotor part # 43512-30371 which is a two-piece design and is much pricier found ONLY on the RWD F-Sport model.
It is a bit confusing they way the list parts sometimes because it makes you think it wouldn't fit your F-sport the way its written. It would be clearer if it said "AWD F-Sport Models" but i guess the parts specialists know the exact fit based on VIN and their own experience.
The following 2 users liked this post by AJLex19:
Measured (01-19-21), WBenz (01-12-21)
07-24-21 09:39 AM
msgs350
Wheels, Tires & Brakes Forum
07-10-13 04:13 PM
illini19
11-05-10 01:59 AM
GS350Lexus
08-29-09 08:52 AM
