Battery Replacement Warning
Does the GS 350 give a warning for when the battery needs to be replaced? I have MY13.
Thanks.
Thanks.
Neophyte2b (01-12-21)
Unfortunately it does not warn you that you need to replace it. One day I went and tried to start the GS and it struggled. I knew the battery was going, my mechanic confirmed and I replaced it with an aftermarket brand with better CCA's.
Usually a load test once a year when you do your oil changes or typically done for free at some places like Autozone to confirm if you need to change it soon.
jsch222 (01-13-21)
Don't let your battery get too old...I got a check engine light where the low battery voltage was causing an issue with the ECM:
https://www.clublexus.com/forums/gs-...ode-p2610.html
I suggest testing the battery and replace if needed. Batteries for these cars are reasonably priced and not worth the risk getting stranded or damaging a computer module.
A slow crank during the winter is how it warns me.
jonathancl (01-15-21)
7 year old battery - safe to replace it and be done.
Thats way too high. It should be part # 00544-MF240-575...see this thread:https://www.clublexus.com/forums/gs-...l#post10717036
When I went to the dealer, they wanted a reasonable amount - it was under $250 for both battery itself and install.
I looked up the part number at a Lexus dealership, and it says that the battery doesn't fit my vehicle:
Is that correct?
Thanks.
Is that correct?
Thanks.
