Headlight Condensation
Have had my 2015 GS350 F sport for over 2 years. I purchased the car at a dealer with 150 mile warranty and my house was over 200 miles away, so I knew it would be void when I arrived home, but everything checked out when I bought it. When. I got home I noticed condensation build up in the drivers side headlight a few days later. Lexus quoted me $1600 for a new one so I lived with it until a few months ago when the bulb burned out. I decided to get a used one on ebay for $800 from another 15 GS350 F sport hoping to kill 2 birds with one stone. Long story short, I noticed condensation build up in the replacement one as well! Do I just have bad luck, and need a brand new headlight? Or could there be another issue that is leading to the condensation?
Has anyone else had a similar issue? Will sealing it resolve the condensation? Thanks in advance!
Is the bulbs and the ballast installed correctly? Other than the headlight being damaged, the only openings is the bulbs/ballast. The headlights are sealed and normally will never have this issue.
I changed my factory HID headlights to LED and one of the headlights came from a car that was in an accident, with broken tabs I repaired, no issues. The only way a used accident headlight would have this issue is if the housing was cracked.
Thats a decent condensation buildup - there must be an opening that is allowing air and moisture in. Check the headlight carefully to see if there are any small cracks along the edges, any sliver of an opening from the housing.. You may need to remove it to carefully inspect..not a common problem on the 4GS so you do have a bit of bad luck on this if you have two bad headlamp assemblies!
Here are some helpful threads with similar experiences/fixes/suggestions:
https://www.clublexus.com/forums/gs-...hat-to-do.html
https://www.clublexus.com/forums/gs-...e-problem.html
Yes there is, check if the o-ring is there, and take off/reinstall the ballast and the turn signal bulb door. The only other explanation for your problem is the headlight housing is damaged/cracked or someone opened it up before and didn't reseal it properly putting it back together.
MichaelFl
11-10-18 09:17 AM
