Squeaky Driver Side Seat
My seat has started to squeak every time I move around in it. Any thoughts on what I can do to fix that? Thanks.
The squeak is coming from the back support. Any suggestions?
Neophyte2b (02-10-21)
If you remove the back panel you get access to everything related to the backrest. There are two straps you unhook under the seat. Then lift up the lower back flap and it reveals 2 screws. Once the screws are removed, just pull it off, only held on by clips at this point.
This is what the back of my lux seats look like:
If you pinpoint the squeak with the back panel removed you might be able to fix it.
703 (02-11-21)
Thanks! @peasodos comes through again!
It's strange, but ever since the post, the seat hasn't squeaked. Before then, it squeaked every time that I was in the seat. I'm assuming that it'll squeak again. I'll keep everyone up-to-date.
Could be the plastic expanding and shrinking from the cold weather and heat? Maybe just a fluke? Keep us posted.
