RSR rear shocks blown. Options for alternative shocks?
Hello, 4GS family. Probably around October time I had purchased RSR coilovers without the AVS from another member on here. He had said the RSR coilovers had only 10k miles on them and had perfect compression. Once I received them in the mail, the rears are blown and my buddy had installed them for me, but he could not get into contact with me that day to let me know they were blown. I work at a hospital and around that time, I had college students come with COVID and such since college had started back up and they decided to throw parties. That's beside the point. I wasn't able to pick up my phone that day due to it being super busy, so my buddy installed them for me. So pretty much my 2013 GS350 is a garage queen at the moment due to it not being driveable because of the rear shocks being dead. I have another GS and an RX that I've been driving for the time being, but I would like to get back into my daily car. RSR had quoted me roughly 400 shipped per shock and I would like to know if there are any other rear shock options that would be high quality and perhaps a better price. I'm currently about 2.5 inches lowered all around. I have no wheel gap. The seller hasn't been much of help so I'm out of some money and have to look for new rear shocks.
initial (02-25-21)
It would be best to stick with replacement RSR rear shocks and just bite the bullet. Its expensive yes but since you have front coilovers installed, its best to stick to the same type of setup front and rear. You dont want coilovers in the front and lowering springs in the rear, it would ride and handle weird. So I really see you only having two options. Go to a lowering spring setup like the RSR Super Downs front and rear with your original stock shocks, or get replacement RSR rear coilover shocks. I would not mix and match.
The following 3 users liked this post by Seatown206:
You need an adjustable length shock to dial in shock stroke to match your coilspring height since you are lowered 2.5". A non-adjustable height shock like OEM or KYB isn't going to work properly as its operating stroke is much higher than your ride height. That shock will be mostly compressed at your static lowered height and probably be on the bump stop
That said, call RS-R and get all the info you can on their rear shocks - min and max stroke, recommended shock height at their recommended ride (spring) height and rear damper lower mount specs (diameter, thread, length,etc..) .
You need a damper that is going to match your rear coilspring height and 8K spring rate. BC will sell individual parts or just their rear kit. Fortune Auto may as well. Tein's use a 12k rear spring so their off the shelf dampers for the GS kit will not work but I imagine all coilover manufacturers have a damper that will match whatever specs you need. The dampers are just cartridges that screw into the lower mount. All you need to match is stroke, spring rate valving, bump stop height, etc.. Also QA1 could be an option.
https://www.bcracing-na.com/products...Filter=Dampers
https://www.bcracing-na.com/products/parts/lower-mounts
You may not need new rear lower mounts if the RS-Rs and BCs use the same shock body height, diameter, thread, lower mount height, etc..
$400/shock is ridiculous when you can get a BC for <$100 each +$50 per lower mount should you need it.
Hope this helps..
Neil
Hope this helps..
Neil
The following 2 users liked this post by Neil64:
initial (02-25-21),
thisguy_06 (02-25-21)
Like Neil mentioned, you could possibly get BC to properly valve you a set of new shocks, just let them know what spring rates your RSR springs are.
I'd be pessimistic in hoping that BC's shock body will fit in the RSR's adjustable sleeve, so be ready to buy a whole new shock and adjuster.
initial (02-25-21)
initial (02-25-21)
initial (02-25-21)
Hope this helps..
Neil
Hope this helps..
Neil
Can you perhaps link me to it? Also are there any threads about the airlift shocks?
I called a couple shops to see if they could rebuild, and many of them said they don't recommend rebuilding it. They told me I'm better off just sticking with RSR sending me new ones or find aftermarket alternatives.
Which model of RSR's did you get and did RSR offer to rebuild them for you at all? I contacted them several years ago out of curiosity, and they said they do offer rebuild services but if I wanted a spare damper to save on down time, they offer that as well.
I think I read that Tein might do rebuilds for other manufacturer's dampers as well.
I have a set of Sports-I non AVS coilovers for an AWD model I've been trying to sell locally with no luck and haven't posted on the forums yet. After taking the bottom mount off the rear struts, there's a snap ring on the bottom of the damper so these are definitely rebuild-able.
Rear damper with lower mount removed
Rear damper with lower mount attached
If you plan to go the Airlift route:
https://www.airliftperformance.com/product/78667/
Try reaching out to a vendor to see if they can source the shocks only.
initial (03-03-21)
Car hasn't been driven since October. It just sits in my yard lol. I've had previous cars and have been on various forums where people sold used suspension. I have never ran into any issue. This is my first time dealing with this bs (excuse my language)
Also try motorcycle suspension shops if you have one local to you. Some of them can rebuild car coilovers since they are similar to motorcycle shocks and forks. They only need to source the seals, O-rings, shims, and maybe some valves.
A little warning for the Airlift rears; the max height on the rear shocks are shorter compared to RSR and other coilovers. What height was your car set to when your friend did the install? I'm curious about what your friend found when he said they were blown. I've also been scammed years ago when I bought set of used Tien Flex and they started leaking less than a week after install.
Have you tried contacting other suspension companies to ask if they can service them for you? Maybe try calling RSR again and ask them to recommend a rebuilder.
