Deflowered my Quickjack installing Exhaust and Spacers
How long have you had your QJ? They might goodwill it if it's a few months out of warranty.
Air was leaking from the chrome part
That's actually a really good idea...I'll try that method this weekend.
I bought the QJ Dec '19 so I'm well out of warranty. They were very helpful with small replacement parts but if I do find a cylinder leak, I'll give them a call.
I think part of my frustration with using the QJ is that mine doesn't lift both sides at the same height, so one side will always make contact first and it takes me a while to line things up jumping from side to side.
It almost sounds like you have air in your lines. Mine did that before when I first set it up and after a few bleeds, they both lifted smooth and even.
The problem I'm having is when trying to disconnect the lines from the pump. I have to hold the down button on the remote just to get the quick connects apart.
2GR (03-05-21)
Another good point. I'll re-bleed as well this weekend. Hopefully that will solve one of my issues.
Thanks
Thanks
Can someone show where exactly you are lifting on the pinch welds? I'm looking at the double pinch locations and my SLX w/extensions don't seem even long enough.
2GR (06-21-21)
Is that an Ideal single post lift? Do you like it? Is it fast to setup and use? Is there enough clearance to access the transmission for fluid changes? My heaviest vehicle is a 2014 Tundra crew cab 4x4. I believe it weighs roughly 5,900lbs with a cab-high cap. do you feel this lift can handle a vehicle that size just fine?
At the furthest points that the extensions allow - the blocks will be at the furthest points on the extensions towards the wheels. There's some splash shields that will come in contact with the blocks (front I believe?), but shouldn't be of concern or get damaged.
It doesn't fully reach the center of the pinch welds. It's one of the many frustrations I have with the QJ. The extensions are heavy, bulky, and expensive and don't even reach the centers of our pinch welds. Kind of wish I didn't buy the pinch weld rubber blocks too.
ok, will look next time I try. Was concerned with not lifting them right at the center. As one of mine is already bent; front someone jacking it up from one side I think. Thank you for your reply.
thanks for the confirmation. Have you had any issues not jacking them up from dead center? Bends etc?
No issues not lifting dead center of the jack points, but for the price I feel like QJ is just cutting corners.
For the 4GS, try sliding the Quickjack frames toward the center of the car instead of using the pinch welds. You can use the frame rails as the lifting point, even for the SLX models. If you look under the rear doors of the car and towards the center and forward of the rear door, you'll see a cut out in the plastic cover where the frame rail is exposed. Only one tall rubber block is required for this placement. I have a 5000ext and when I first got it, the parts didn't match the instructions and it also came with a leaking air cylinder. It only took Ranger/Quickjack a 6 week time span to send me the wrong hydraulic/air cylinder from the 7000 model and then send me another leaking cylinder until I got a working one.
I did notice one thing tho, after lowering the car, the blocks which came in contact with the frame rail cutout in the rear, had a straight wet line on them... Both blocks. I did notice some sort of padding on that area before lifting, not sure if it had some moisture caught in it... But also a bit paranoid if there was some kinda fluid line running by there.......
I know this is a really old post, but I was getting super frustrated since I just got the QJ 7000TL and I couldn't figure out how to get it to lift the GS, but then found your post, a life saver! Worked great!
With the QJ7000, it should be long enough for you to use the pinch welds but might be too long to clear the front and rear wheels. Have you tried lifting from the pinch welds yet?
That's strange. Maybe some moisture on the frame rail since there are no lines or drains in that area?
rico501
02-27-21 02:40 PM
dfwjohnd
01-30-18 12:23 PM
chrispy
Performance
32
03-17-16 11:05 AM
Ls430es300
03-27-11 09:07 PM
