KYB Gas-a-Just shocks/struts AVS 3 week Review
Old 03-25-21, 10:14 PM
  #31
00goobs
00goobs's Avatar
Originally Posted by thallium
Is there any alignment or calibration that must be done or will the car auto-calibrate?
I'm 91% sure it is either CW or CCW. When I installed my springs, there were only 2 wires for the motor atop the front struts. So no position feedback AFAIK.....
Old 03-25-21, 10:16 PM
  #32
00goobs
00goobs's Avatar
Also, thanks OP for the review and PNs. This forum is pretty awesome with all the help provided and reviews on parts and good places to buy them. Great first hand experiences from the community.
The following 2 users liked this post by 00goobs:
CAKETOWN (03-26-21), mtucci3 (06-07-23)
Old 03-25-21, 10:46 PM
  #33
Cwang
Cwang's Avatar
Just got my rears installed today at the dealership. Very impressed! It drives like new, I was hoping to be able to notice the difference but it's night and day, I can almost feel the car drop when I change from Splus to eco, amazing. Funny thing was, the shocks(I supplied) were ~$180, labour $360! Beats $700 for a single official Lexus shock.
The following 2 users liked this post by Cwang:
CAKETOWN (03-26-21), JDR76 (03-26-21)
Old 03-27-21, 02:17 PM
  #34
Cal916
Cal916's Avatar
how many mile did you have on yours and did you replace them in pairs
Old 03-27-21, 02:42 PM
  #35
Cwang
Cwang's Avatar
130000km so about 80000 miles I guess? They've been noticeably bad for the last year so should have been changed earlier, just didn't know it was the shocks themselves.
I replaced the rear pair. The fronts are still original, although I have a suspicion that the previous owner may have changed them sub 40000 miles. If the fronts come up cheap I'll buy them too.
Old 03-27-21, 02:51 PM
  #36
thallium
thallium's Avatar
If anyone is interested, Rockauto has only the KYB rears AVS compatible in stock right now and shipped they would be about $190.00 and there is a KYB rebate you can get for $25 so it would be $165.00 for both.
For those that have replaced the fronts, do the shocks come with any boots or covers as the ones on my front are tearing off and loose, or are those Lexus parts?
Old 10-31-22, 04:47 PM
  #37
mkmckinley
mkmckinley's Avatar
Sorry for the necropost, but when reinstalling the shock with AVS, how do you clock/time the position of the strut to the position of the AVS actuator?
Old 11-03-22, 07:28 AM
  #38
Raptors86
5th Gear
Raptors86's Avatar
Do people often change the springs too at the same time as the shock? Rock Auto seems to have all four AWD with AVS for a good price. Car has about 170,000 KM on it and does squeek on all corners.
Old 04-24-23, 08:56 PM
  #39
RuninRoach
RuninRoach's Avatar
Is this correct?
Rear Right + Left - KYB 7240000 Gas-a-just Gas Shock
Front Right - KYB 7210000 Gas-a-just Gas Strut
Front Left - KYB 7210001 Gas-a-just Gas Strut
Old 04-25-23, 04:03 AM
  #40
mkmckinley
mkmckinley's Avatar
I only did the rears, but yes KYB 724000 are the parts I used and they were identical to OEM. They came with the little rubber bump stops too.
Old 04-25-23, 08:21 PM
  #41
richard203
richard203's Avatar
late post but for future people, for me i screwed up the mounting holes and the avs wasnt in the right place ( I marked where it goes). Before you release the spring test fit the strut and avs actuator if its right before releasing the spring compressor you can turn the rubber top to adjust the bolt holes and the avs actuator. First time doing it and i have to compress the spring and etc all over again and if one bit of the mounting bolt is off it wont go into the mounting holes. I heard that if you equip with avs only 1 way to go in, so if u doing it urself double check before releasing that spring.
The following 2 users liked this post by richard203:
mkmckinley (04-29-23), mtucci3 (06-07-23)
Old 06-07-23, 05:21 PM
  #42
mtucci3
mtucci3's Avatar
One additional question. Strut mounts. Did you replace these? They're quite pricey and am wondering if it's necessary to change these.
Old 06-07-23, 05:39 PM
  #43
mtucci3
mtucci3's Avatar
Also, do you mean to leave the spring compressed, put the mount through the body and make sure that the AVS actuator fits? Or will the AVS actuator only fit one way, and you can adjust it with the strut out of the car? Sorry if I don't make sense lol.
This is extremely helpful!
Old 06-07-23, 06:13 PM
  #44
er34
er34's Avatar
I had all 4 shocks/struts done on my 2013 Fsport. Biggest difference is the rear tightened up alot and no longer bounces with road undulations even under normal mode.
In sport+, the fronts seem less hard as stock but does stiffen up compared to normal mode, it's hard enough so when hitting bumps it doesn't feel jarring.
fomck
GX - 1st Gen (2003-2009)
03-23-21 11:08 AM
shouldibuy
09-02-19 11:24 AM
fcc
09-15-14 12:08 PM
Wahlnutz
02-07-13 09:42 AM
ezwinner70
04-11-05 11:47 PM
Quick Reply: KYB Gas-a-Just shocks/struts AVS 3 week Review
