Bullets Garage Door Panel LED Upgrade, DIY!
I don't know why they couldn't just give the driver the ability to adjust the brightness of the accent lights like you can with the instrument lights.
Does nobody know what the interior light kit is I asked about above?
Why did I have to click this link? I must do this now.
Op, thanks for sharing. Just did this mod over the last 2 days. Am a novice at DIY and this video helped a lot. Took me almost 10 hours to do this mod. Front doors were the hardest.
It turned out great and love the neon blue.
Have left over leds planning to change the footwell lights with these.
Thanks again Op.
Thanks again Op.
Im2bz2p345 (04-04-21)
Did anyone else cringe every time he yanked on the door panel, fearing he was going to hit the door of the other car?
For the uninitiated, the fun starts at 4:10:
Knucklebus (04-05-21)
After seeing what he did to his poor GSF's front passenger side door while jacking it up... hitting the door panel wasn't bothering me. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
https://youtu.be/RfB7YWZ5j6E?t=250
I'm having a 2-post lift installed. Scheduled for a few weeks out. I fear something like this with my GS. My Buicks have full frames and they won't have an issue.
eddie420 (04-05-21)
Thanks again Op.
Thanks again Op.
I wonder if I can get a RGB light strip and wire it to a central controller like they use in some computer build? It would have to be either bluetooth or a remote control. Running the wires is a turn off but it wouldn't be hard. I'm guessing there would be a 3rd wire to trigger the color signal. Hmmmm. I'm so jealous of my mom's X3 with the interior light package.
Mrslady (04-06-21)
Took me two days but very happy with the result.
https://youtu.be/fTKINi6LI7E
I found out via PM he used Moromito Pixel Glow Roll RGB leds strips and Moromito XBT lighting controller:
https://www.theretrofitsource.com/pr...M-B?quantity=1
It's a lot of work because you have to run wiring from inside the car to all the doors.
Im2bz2p345 (04-15-21)
Still working on the footwell lights.
If anyone else is attempting this and do not feel like cutting wires and soldering. I got these from Amazon. Wire connectors and and Led connection kit. Found this while trying to figure out how to wire the foot well. Will use these to tap into the existing foot well led.
