Shift knob/assembly
Good evening. I was hoping I could get some help & guidance with something. I have an 18 F Sport that took the place of my 14. I really preferred the shift **** on the 14 as opposed to the 18. I went on the assumption I could just get a **** from a 13-15 model, and just swap them. Well, I should never assume as its not that simple. Received the part today and went down to the garage to swap them. Trouble is, it appears as though I will need to change the cover/boot as well because the interlocking mechanism doesnt fit. Does anyone know If the cover/boot assemblies are interchangeable? Or have I wasted money on a shift **** I wont be able to use?
The shift **** and the cover/boot are not interchangeable between the pre-refresh and post-refresh. However, you might still be able to zip tie it all together. See this helpful thread as many folks have swapped newer shift ***** onto the older 13-15 models, and swapped 2016+ ***** for older ones based on preference: https://www.clublexus.com/forums/gs-...swap-pics.html
From post #16 on that same thread, a fellow member replaced their 2016+ shifter with the older one: https://www.clublexus.com/forums/gs-...l#post10320517
Cobra611 (04-23-21)
You did exactly what i did, as you would assume the **** simply connects to the existing leather boot
You just need to purchase a new leather boot, there is the older model and the newer model. Do a bit of searching, im ordering mine from this website:
https://www.lexuspartsnow.com/parts-...x_bracket.html
Scroll down to the middle, you will see the different leather boot options, essentially there is the 58808-30190 and the 58808-30230 variants
the 30190 is for the earlier model shift ***** and the 30320 appears to be for the later model ones. google image search the part numbers to get an idea of what your buying
good luck!
ps: the shift **** literally screws off and on, no need to pay someone to do this for you.
good luck!
Cobra611 (04-23-21)
good luck!
good luck!
Thank you, both!! DiscoJango, so basically I all need to do is a get the boot from say a 2014 GS F Sport, and I'll be able to take the clip from that boot and attach it to my 2018 boot? Then, obviously, be able to connect the shift **** with the new clip & my current boot?
You cant just change the clip part unfortunately...
Cobra611 (05-03-21)
good luck!
good luck!
You will need to remove your current leather boot and install the old model one, however, to install the leather boot, you need to take some parts of the middle console apart. It shouldnt be too difficult, theres a few threads here which outline the process
@Cobra611 any before and/or after pics??
AJLex19 (06-08-21)
