Are Lexus GS expensive to maintain???
Really? The engine itself sure but the rest of the consumables are rather pricey in comparison. Full disclosure, I'm in Australia so we pay Australia tax on everything, you lot have absolutely no idea how good you've got it.
Tyres are more expensive than Camry tyres ($400 vs $200 each here) and I can't rotate or swap them(fsport) so I get frig all life from them. Camber is completely buggered from factory and is not adjustable so they are not roadworthy long before they should be.
Front brakes are hideously expensive (over 1K) as we don't have aftermarket options here. Camry brakes are cheap and aftermarket options aplenty even here.
One of my hub threads was stripped (previous owner), of course it's a GS/RC specific part and costs $600, not $200 like the OEM Camry hub.
Shocks are a grand a corner, Camry a hundred or two. That said when the KYB ones become available it changes that, I've already managed to get cheap rear shocks.
F Sport with staggered wheels/tires is the exception, any car with staggered tires and rare Brembo's is going to be more expensive in that department, you can just buy 2 matching sized wheels so you can rotate your tires and install standard brakes, that is the first thing I would do if I got a RWD F Sport. Lexus parts are normally more expensive then Toyota's along with dealership prices and it sounds like Australia is really bad, if you look around and do DIY it will save a ton of money. The GS is a very robust car with few trouble spots, it is generally about the same as a Camry in most cases aside from the tires being more expensive and in the F Sport case they can't be rotated along with the Brembo brakes, you can switch them out though to save a lot of money in the long run, other then those things you are not doing much more then a Camry. A LS460 is a totally different story, it has several trouble spots and the prices are very high in many cases to fix them.
If replacing with OEM parts all cross shop the comparable toyota part. Save yourself 10-20% on the same exact part with a toyota box. The car is relatively cheap to maintain; especially when compared to the competition. That’s one of the main reason i use mine as a commuter.
Club Lexus Editor
GS F (2016-present)
08-25-16 11:30 AM
Club Lexus Editor
GS F (2016-present)
06-01-16 04:21 PM
