2015 GS 350 license plate lights
I noticed that both license plate lights are out. I am seeing that it is not just a simple bulb replacement and requires me to replace the whole assembly. Then also found out these things don't go out very often?
Would something like a ijdmtoy or similar work in hopes its just a bulb/assembly issue and not a larger issue?
You can buy them from iJDMtoy here: https://store.ijdmtoy.com/products/o...ssembly-75-359
Hope it helps!
AJLex19 (05-18-21)
Check out the thread I did on replacing the license plate lights here: https://www.clublexus.com/forums/gs-...arket-led.html
Hope it helps!
Hope it helps!
At least iJDMtoy has a fair return policy.
