GSF Wheels
Im picking up some vossen wheels that were previously on a GSF. Just wondering if the wheels and tires might too wide for my 2020 gs350 f sport and have issue with rubbing. Wheels are 20x9 +38 on 265/30/20front amd 20x10.5 +45 on 295/30/20 rear. Thanks in advance
The wheel specs themselves are fine, but the tires might be a little wide. Typically we'd be at a 235-245 at the front and a 265-275 at the rear on a staggered set up.
RaiderRick (07-09-21)
Yup agreed. wheel sizing is fine just test fit to make sure fronts will clear brakes with that offset otherwise you may need a 5mm spacer (vossen sizing for F-sport I believe is preferred at +32 for the 9 inch wheel, but might still be ok depending on design), but tire sizes definitely need to come down as those sizes will rub all over.
Damn 265 and 295? I think that's way too wide for our cars but they fit the GSF without rubbing?
Oneflyguy
05-31-11 05:34 AM
SpOrTDZiNe
Wheels and Tires Classifieds
44
05-18-10 09:52 PM
