Akebono for 13 GS 350 Non F Sport AWD
Do akebono act 118 pads squel for anyone with a base (lux) awd ?
Is all the squeling complaints only related to F sports (2 part rotor) and RWD ?
Planning on running oem rotors and akebono pads just for the front to reduce brake dust.
Absolutely no squeal for me with rhe Akebono pads on front. Please use the grease they supply in the box.. I believe I used Wagner for the rear.13 AWD just installed myself a little over two months ago.
Be aware. There are 2 different options for most of the Akebono pads. A OEM line and a Performance line. At least for my GS there is. The OEM is Ceramic mostly and is low to no dust. The Performance does give better braking and longer wear, but does produce brake dust more. Neither will make any noise as long as you install and lube and clean correctly.
I have been using Akebono for years on my Lexus's and all other cars. Its the only pad I use. Its a very good high quality pad.
2GR (07-26-21)
hydronos
11-16-17 11:00 AM
