20mm H&R spacer question
I have a 2012 (yes they came out that year in Australi!) rwd gs350 f sport with 19" rims
Am looking to get 20mm H&R spacers for the rear wheels. Doing some searching, there only appears to be the 'bolt on' type and not the version which comes with extended studs for you to replace. Is this correct? If i search for 15mm spacers then i can easily find the version with the extended studs...
If someone could also confirm the model number i need is 'h&r 4065600' ?
When i search the following model number also comes up 'h&r 4065601' but im not sure what the difference is between the two...
Thanks!
Thanks!
4065600 is the right part number for the 20mm with its own studs (adapter style that bolts to your existing studs, then bolt wheels to the spacer studs). From H&R these are known as DRM style.
The one where you have to replace the studs is known as the DRS style spacer form H&R https://propartsusa.com/products/h-r...-40656014-4438 (note: I am not certain this part fits, though the descriptions indicates it would).
They never failed and the bolts on the spacer were still properly torqued when I went to remove the spacer.
To figure out if it will suit my car, would i just need to confirm the measurements? So i would look for H&R DRS 20mm 5x114.3, 60.1CB, for studs 12x1.5mm ?
