2013 GS350 restoring to original shocks
That's great information, thank you.
Do you know if the additional height of the AWD vs. RWD is based on hardware or spring length? I know the front struts are completely different to clear the front half shafts. I don't want to hammer my shocks with lowering springs, but I would not be upset with RWD ride height. I don't understand why Lexus insists on making their AWD sedans (except for the early 3IS) sit like scared cats.
Lexus may deliberately give the AWD more ground clearance and spring travel to cope with non-bitumen surfaces.
Based on a spring rate document that I saw in a different thread, all 4GSs are set up with front springs that are stiffer than the rears, which is readily apparent in my car's steady state understeer. Reducing front spring rate would go a long way towards neutral handling.
