GS-F LCA bushings installed on GS350
#46
Did you load up the front suspension before you torque the LCA bolts to the proper spec?....or left it dangling on a jackstand and tighten the bolts?......
#47
4GS350 (07-09-24)
#48
As BCLexus noted, I paid attention to the advice of all around here and torqued it all while flat on the ground.
Best mod to the car so far, even with the alignment cost. I did the lifetime alignment option at Firestone, so for future mods it's all part of the coverage. They did mention a stuck adjustment on the RR, that toe angle adjustment won't break loose. First stuck fastener found on the car so far as well.
AdaptLab
Performance & Maintenance
09-05-18 06:52 AM
lyonkster
12-09-10 01:53 PM
