Transmission Flash
It seems like your transmission is gearing down appropriately. Mine seems like it goes into neutral and takes its own time figuring out what gear it wants to be in when I step on the gas. Evidently I am giving it the returned throttle before it decides and it causes the car to jerk as if I have popped the clutch. The more throttle I give it the harder the jerk.
Not sure if it was mentioned, but I would check the fluid level after driving a while to get everything up to temp. It won't hurt to go through the filling procedure to be sure the correct amount of transmission fluid is in there. Filling cold and filling hot does make a small difference, and human error is always a factor.
Every time I hear a delay in engagement, I suspect fluid level then work from there.
Thank you, everyone for these great ideas! If you have more please share.
Give you my thoughts. Seems you said the Trans was just out of a shop on repair? Rebuild after failure?
So you had the car for a min right? The million dollar question is.......... was the car doing this when the Trans was ok before the rebuild? If was not back to the Trans Shop that did the work I would go.
If it was doing this with the original Trans, before it was failing then it would be normal has it was right? The 8 speed Trans has had lots of complaints about this from many. Before I got my 13 6 speed I drove a few 8 speeds and passed up on them as I decided I could not live with that Trans doing that. I experience the neutral to downshift and gear braking and on slow turns on and off acceleration also on the 8 speed. I why I love my 6 speed.
maiahsdad (11-09-21)
Universe93
ES - 6th Gen (2013-2018)
14
03-07-19 12:44 PM
