Transmission Flash
Transmission Flash
Greetings, everyone. I am noticing that when I slow down to go over a speed bump, or any other time I slow down to less than about 7mph and then hit the throttle again, it feels like the car has been in neutral and I popped the clutch. So much so that if I press on the throttle enough the car will actually jerk. Is this normal? Just got the car back from having the transmission replaced.
Shello (11-02-21)
The only question I would have is do you get the jerking motion regardless of how hard you press the throttle after slowing down? Not absolutely sure, but I would venture to guess the transmission may still be "re-learning" your driving style if you're pressing the gas pedal hard. See if the behavior subsides after a few days. If it doesn't, bring it back to the place that installed the new tranny and have them evaluate the issue.
maiahsdad (11-01-21)
While I can't say for sure, it sounds like the transmission is in a higher gear and you are punching it enough to force a downshift. Try it in ECO, Normal and Sport modes to see if there is a difference. That will possibly tell you the transmission isn't doing anything wrong but the computer doesn't expect what you are doing. Sport should hold gears a little longer than ECO or Normal modes.
It feels like I have mashed in the clutch until I go over the speed bump and then I pop the clutch. And sometimes it will knock all the way down the first year if I am beneath 10 mph to cause a jerking sensation as well. But I'm not punching it. Thanks for this feedback.
I've had this issue in my Infiniti and now my Lexus. It's just that the computer doesnt expect you to tap the gas at the last second. I'll slow down and it feels like the car is about to drop a gear, then I gently tap the gas and it catches the gear. The car is getting ready to drop the gear, but then you tap the gas at the right time so it will catch itself instead. Sometimes this happens and sometimes it doesnt. I'll roll slow enough to where it wont go down to second, then tap the gas and no jerking; but that means im rolling through a stop sign lol.
That's it exactly! Is there any kind of a transmission flash or something that will allow the car to kick down all of the time? In my Cadillac STS, you can hear it noticeably when you are slowing down. I think in sport mode, if I'm at full throttle,, and then slow down I can notice my car ticking down. I wish it would do that all of the time. Does anybody know if it's possible? When I'm going over a speed bop it forgets to kick down fast enough. I think that's what I've been trying to say.
Do you have the 8 speed or 6 speed? I don’t have the issue in my 6 speed but what you are describing is common in the 8 speed. I even get the same as you described in my LX. More gears. More gear hunting.
Interesting. I dont have the issue like you. The only time i have something close is if i brake hard and the car downshifts but i hit the gas mid shift.
