This issue came up recently and it’s odd. Seems to only happen when I try to start the car when I haven’t shut the door yet. Once I’m in the car and shut the door it starts no problem. Any ideas why this is happening, starter?
Won’t let me post video from my phone so I’ll have to describe i suppose. Car flashes as if it’s going to turn on, has a couple of clicks then shuts down. Does that a few more times with more clicking and eventually it starts up after a minute or two of trying to press the button. Anyone experienced this? Thanks for your help. Screenshots from the video attached
flashes all the lights a few times. Needles illuminated once before finally starting. Makes odd clicking noises basically for a minute while it acts like it’s going to start then black to blank screen sometimes with key symbol
I'm just going to say that the two times I had this happen(flickering dash, ticking sound when starting), I had a weak battery.
Likely the reason your car starts up fine with doors closed is because there is less drain from all the cabin lights. I would change out the battery before you end up getting stranded somewhere.
Thanks man, open to any other opinions as well. Looks like an oem battery that has 84 month warranty which would put it about a year out of that if new. I’ll try that first
