p0a0f-204 p3190
Looks like you have engine rpm speed displayed.
My all photos from techstream.
Maybe there is some mechanic who knows where the problems are.
In my country there are not many of these cars and people who know them.
Welcome to the CL forum.
So were those pictures from techstream taken when the engine was running? It clearly shows your rpms near 1K and the 12V battery voltage reading to be 14V, which would only happen if your vehicle was started.
If not, does your starter crank the engine at all? You should hear the vehicle trying to start.
Are there any errors that show up on your dash if you put the car in accessory mode (when you don't have your foot on the brake and you press the start button)?
Check this video out (from Toyota Prius, which shares a lot of the same technology):
^I would suggest that you start by doing something relatively easy - inspect/cleaning your Mass Airflow Sensor.
Next, try cleaning out your throttle body:
If the engine still doesn't turn over after those two things, it could be a fuel pump issue (service bulletin taken from a RX 450h), but I would try the above steps first: https://static.nhtsa.gov/odi/tsbs/20...33806-9999.pdf
~ im2bz2p345
~ im2bz2p345
eddie420 (12-04-21)
Hi, engine working 8 sec and stop. I change mass airflow sensor.
Look on the pictures on fuel press 4500kPag.
I sow all movie with this code in net.
Please do us a favor and report back after you figure out the issue. It will help others who experience a similar problem/the same codes. We don't come across too many problems/codes thrown with these engines since they are fairly bulletproof.
~ Im2bz2p345
~ Im2bz2p345
BKzSC400
NELOC
27
06-03-08 08:17 PM
