Valve or Injector noise ?
Hey guys I have a 2014 with 77k. I was running pennzoil platinum 0w20 for the last 4K miles that I’ve had this car and had just changed the oil with Kirkland full synthetic 0w20. As I started it to bring it up to pressure I noticed for the first time what I believe is a valve tap.
I had a 2006 IS350 so I know these injectors are noisy but I don’t recall ever hearing this before on the GS…
here’s the video of the noise …
https://youtu.be/yUnHxcwOhJQ
thanks in advance
thanks in advance
thanks in advance
thanks in advance
Here's that thread. Fuel Pump Noise Reduction
thanks in advance
thanks in advance
https://drive.google.com/file/d/1tN9...w?usp=drivesdk
Does the noise change when accelerating? I would try the HPFP insulator mod above and see if that helps.
thanks in advance
thanks in advance
If it were me, the 1st thing I would do is drain that oil and put back in the Pennzoil for comparison and see if it still there a few days and miles later. I know that would be a pain but I would just drain and refill or drain and change the filter again just to see? Being that you think the change occurred directly after you were bringing up the pressure?
Update:
I changed the oil back to Pennzoil and drove it for about 100miles without any change as expected.
I then installed the pump cover as mentioned above and noticed that that was indeed the culprit. The 30-50% reduction is fair to say. Here are before and after videos outside the car with the hood up. Appreciate the guidance fellas
Without cover
With cover
Without cover
With cover
I'm sorry but I can't tell any difference, if you do, that's cool. I'm bummed out as my 2017 sound like is low on oil, smh. I will inquire about the vacuum pump on my next oil change.
sixonemale
09-11-15 08:13 AM
