Anyone know if 16+ LED/Halogen Fog's same design as 13+?
Hello All,
Going to be switching the current front end to the 2016+ F Sport front end. In regards to that, I am trying to figure out if the fog lights from the 13+ utilize the same design as the 16+ front, with the exception of them being LED/halogen. These are the OEM fog lights. I am needing to order the garnishes, but not sure if I also need the fog lights, since I currently have them already on my 13+, which is the same as the Toyota Prius.
Correct, you'll need the 2016 bracket/garnish. The fog light assembly itself is the same for 2013-2020, only difference is the bulb type and the exterior garnish. See my post here: https://www.clublexus.com/forums/gs-...l#post10797742
For MY 2013-2015, the exterior finish of the fog lamp was a circle which showed more of the bulb/housing. For 2016, they purposely designed the exterior of the fog lamp garnish to have a more rectangular finish that would only highlight/show the rectangular LED bulb - fitted to the same circular assembly (parts-bin style business model so they wouldn't need to redesign the fog assembly itself, just the cheaper plastic exterior garnish!).
