Possible Transmission Problem?
Hi Folks!
I wonder if any of you have encountered any transmission problems on your 4GS. Today when I got into the car like normal, put in D, the car didn't move at all. Then I tried to put a little bit gas, the engine revs to 2k~3k, the car start to move slowly. Probably the same speed as idle in D in the normal situation. I turned the car off and ignite it again. Wait for 30s and then put into D. The problem is gone, the car can ran normally.
Have you seen this in your own GS? What could be the problem?
It's a 2013 GS with 85k miles on
Im2bz2p345 (01-19-22)
I asked one of the service writers at Toyota (not sure of how much truth there is), about this and he said to start the car and wait 30 seconds to engage into gear. It might be a safety mechanism to protect the transmission, but not too sure.
This typically happens to me more when it's cold. It's also happened to me with 2 other Toyota's, including an Avalon. 2010, 2012 Camry and a 2015 Avalon. All bought new.
The following 2 users liked this post by jgscott:
Im2bz2p345 (01-19-22),
mtucci3 (01-18-22)
Activating the Snow Mode retards the throttle response so wheel spin on slippery surfaces (snow/ice) is reduced and the vehicle starts in second gear instead of first gear from a start.
Information on Snow Mode should be in your Owners Manual.
Hi Folks!
I doubt you have anything to be concerned about, but I'd give it a bit more time instead of immediately shifting into gear after startup when it's cold weather or when the transmission is not already warmed up...
mtucci3 (01-19-22)
Hi Folks!
