Your most expensive repair to date
Old 05-09-22, 01:04 PM
  #46
MX73
MX73's Avatar
Originally Posted by spineman
Electric Steering Rack $2500...I was not expecting that one. Now it sounds like my right wheel bearing is going. How many miles on your cars when bearings went bad? Other than that, only $50 sunroof seal for repairs
Close to 109,000 miles when I had to replace the front hub bearing.
Old 05-09-22, 01:19 PM
  #47
spineman
spineman's Avatar
Ok I was not just hearing things...lol 101k on mine. You had them replaced at same time for $200 each?
Old 05-09-22, 01:22 PM
  #48
MX73
MX73's Avatar
I paided $100 a piece from rockauto and did the work myself. NSK front wheel hub.
Old 05-10-22, 06:14 AM
  #49
spineman
spineman's Avatar
Just looked them up NSK58BWKHS20. I'm going to attempt to do them myself. Were they hard to get off? Also, when looking at Lexus part numbers they have a right and left? I assume with the NSK it doesn't matter?
Old 05-10-22, 06:20 AM
  #50
MX73
MX73's Avatar
Wow. Just looked them up $175 a piece now. I'm going to attempt to do them myself. Were they hard to get off?
FYI, this is for an RWD. It's not hard at all.
If you know how to do the brakes, then this should be a few more step. Rent a slide hammer and a grab a couple cans of penetrating fluid. Let the fluid do it's magic and slide hammer away. I also put antiseize on the mounting surface.
The following 2 users liked this post by MX73:
CMK (05-10-22), spineman (05-10-22)
Old 05-10-22, 03:50 PM
  #51
JeffKeryk
JeffKeryk's Avatar
I guess I would have to say getting the pigs to stop squealing; er ah I mean front brakes...
Old 05-10-22, 05:17 PM
  #52
jgscott
jgscott's Avatar
Received 1,320 Likes on 1,051 Posts
Technically there has only one expensive repair that can very rarely occur on our GS. Its the Servo motor problem and replacement is rare. That beats the hell out of consistence internal engine and transmission problems of other cars in the class. Both foreign and domestic. Its does help though if you maintain the GS and not just amaze yourself at neglecting maintenance to the objective of driving it till it breaks. lol!
I'd take our problems over a $7500 oil leaking engine problem fix, any day. Rather have a squeak in the morning a few seconds that causes no harm and goes away, or a seeping puddle leak of engine oil on the garage floor that requires 20 shop guide labor hours for some kind of engine tear down for a new $17 seal and kit or worst?
scsc
04-07-22 05:18 PM
mirice41
Wheels, Tires & Brakes Forum
04-30-03 11:09 PM
Carbon J
SC- 1st Gen (1992-2000)
04-15-03 09:46 PM
Quick Reply: Your most expensive repair to date
