Spark Plug Change and Cylinder Head Images On High Mileage GS
A $60k MSRP Lexus. The advise is to cheap out on $60.00 saving in plugs that Lexus has a recommended 60k replace/change interval on by the service requirement. Ok if it excites one to save $60 it's very Weird to me. I wont do it.
Even more Weirdo is those who in other threads say just do what Lexus says they made the car, blah, blah, blah. Weird and hypocritically strange? Its your car take the cheapo advise and dance around at your $60 savings. lol!
I'm gonna trust the engineers who put thousands and thousands of miles' worth of data into spreadsheets and analysis software rather than a few folks who've "always done it this way" (seems to be the most common excuse). As active as this forum is, all these anecdotes aren't going to add up to a statistically valuable sample size.
bclexus (05-04-22)
I know right. I guess it's their bogan right, a 10 yr old Lexus wouldn't be a 10 yr old Lexus without service items skipped! I can't talk though, I deferred my fuel filter change by 45000km until it's next due.
The old, "You can run them a while longer but you are going to need brakes/tires pretty soon." and they tell the service writer to go ahead, while I'm here. I don't want to make another trip.
bclexus (05-05-22)
Don't do any service just put gas in and drive till it breaks. Save penny's. Give a like for don't service post. Its the new GS owners here now thing. Its your car, your choice. Everyone is entitled to decide about servicing their own car. Crazy though to knock those who do the service. Again I remind of what comes later. If you want to experiment and risk go ahead and push the envelope of neglecting and $60k nice car to save $30 on a 7k oil change, no Trans fluid change, lifetime plugs, and cheap low octane gas. Call it a waste of money and do the el cheapen out nothing broke yet Dance. The service and recommendations you can convince yourself of a conspiracy theory. Engines don't have problems ever, transmission don't break, fluids are no needed. Its conspired by all the shops on all cars. The ones in the shop with problems are just lies. lol!
Go through the 1st 4 pages of each of the future of your engine and Transmission you have the same.
https://www.clublexus.com/forums/is-...013-163-2.html
https://www.clublexus.com/forums/gs-...011-153-2.html
Now speaking on the Lexus and the Engineers, just go to a Toyota shop or Lexus shop and ask a Tech who works on them everyday what they think about no need to do this, no need to do that? See if they give you their experience everyday and tell you no need to? Most own a Toyota/Lexus themselves. So from their experience they just waste money on maintaining their own Lexus even though they can fix themselves because they never see a problem. Really? Ok. Yes there are 2 schools of thought and some inexperience of what keeps Toyota/Lexus's so reliable and the reason that built that reliability rep. Good luck on you choice as its 2022 and your car is getting up there, you likely got used that had excellent service history from the prior owner, prior to your ownership and/or your decision to change for servicing, or not choice.
Plugs need to be changed because they a) stop firing/fouled or b) the gap eroded and causes erratic spark. The new iridium plugs won't foul unless you are burning oil and the gap won't open up due to erosion. Most people do it because, just because. Those brand new plugs will look like the 60K plugs in less than a tank of gas. You probably do more good by taking it for a test drive and running it hard, which blows out the carbon.
bclexus (05-05-22)
My wife's 2003 Honda Pilot had no requirement for any service before 100K except for the oil/filter and the rear end which wasn't a differential because with it locked in park and only rear one wheel off the ground, that rear wheel spun like it wasn't attached to anything.
Knucklebus (05-05-22)
Its a motherhood blanket requirement for all vehicles.
The following 2 users liked this post by 703:
bclexus (05-05-22),
Yes you can just drive it until post #14 happens. Don't need to maintain your car, if you don't know you don't know and will think everything is fine until. Yep that's one way to do what you don't want with one's own car. When it breaks you can simply test drive run it hard and it will fix the blown engine alright. ok. lol!
https://www.clublexus.com/forums/is-...l#post10737536
https://www.clublexus.com/forums/is-...ment-cost.html
Exactly, they will easily run 100K miles without any issues. Changing them at 60K is wasteful and unnecessary. These engines will tell you when a plug is not firing as required. They will start dropping a spark once in a while before they get bad enough for the above average Joseph to notice.
bclexus (05-05-22)
I’m not sure what your question is and how that relates to my comment around the spark plug change interval. I’m not suggesting that people drive their car till there is an issue. Simply pointing out the 60k interval has got little to do with actual spark plug performance.
bclexus (05-05-22)
