Spark Plug Change and Cylinder Head Images On High Mileage GS
Old 04-26-22, 10:58 AM
Saadq12
Saadq12's Avatar
Default Spark Plug Change and Cylinder Head Images On High Mileage GS
Changed the spark plugs on my 2013 GS with 205k miles. They were changed last around ~100k from the previous owner as far as I can tell by the reminder set in the car and the condition of the plugs.
Two of the spark plugs were not tight enough and had some oil leaking in to the top - you can see those cylinder heads had more carbon buildup than the other ones which were very clean and had little to no carbon build up. The coil packs were dry and looked new as well.
The following 2 users liked this post by Saadq12:
Im2bz2p345 (05-01-22), LatinLS430 (04-26-22)
Old 04-26-22, 11:32 AM
bclexus
bclexus's Avatar
Received 2,100 Likes on 1,495 Posts
Those spark plugs are good for another 200k miles with no decrease in performance or fuel mileage...
Old 04-26-22, 11:48 AM
jgscott
jgscott's Avatar
Received 1,320 Likes on 1,051 Posts
Oh wait.... the GS350 Gen 4 is a self cleaning motor according to those experts here.
As I have stated before, I have seen the same on a 90k GS350 motors with a Bore scope, and others have too, if they choose to post about theirs.
Unless we can see the fine wire coil windings, inside the ceramic that's only been fired at 40k volts 100 million times. lol! What's so great about the plugs that have been in there?
Old 04-26-22, 01:23 PM
Saadq12
Saadq12's Avatar
Im sure these plugs would still work for another 200k but performance was definitely noticeable after I changed them. GS got a lil more pep in her step now.
Old 04-26-22, 01:30 PM
Saadq12
Saadq12's Avatar
A little carbon is totally normal and well this is proof that they are kind of self cleaning via the dual port injection system..if you compare the two cylinders heads the one with the leaky spark plug had more carbon build up cause it was leaking oil into the chamber and letting it gunk up while the other head had almost no carbon build up. I’m convinced it works and that’s why the 2GR-FSE engines are solid.
Old 04-26-22, 01:32 PM
Asav
Asav's Avatar
This comes up all the time...plug change intervals. TBH, Not being a car expert but knowing enough to be reliably dangerous I would rather just spend the 100 bucks and 2 hours time doing this for my own sanity. I am not letting plugs in any vehicle go past 75-80k ever for my own peace of mind. This is a cheap fix on a Sunday morning in the 4GS.
The following 4 users liked this post by Asav:
GregCanada (04-26-22), JeffKeryk (04-27-22), JUTMSS32 (04-26-22), Saadq12 (04-26-22)
Old 04-26-22, 02:20 PM
jgscott
jgscott's Avatar
Gotta love the just drive it till it something F's up crowd always. Wait till a check engine light or something is not right.
Hating on the installed new plugs and cleaned up upper intake, and the car drives so much better. I wonder why? lol!
A crystal ball moment:
https://www.clublexus.com/forums/gs-...011-153-2.html
https://www.clublexus.com/forums/is-...013-163-2.html
https://www.clublexus.com/forums/is-...2006-2013-163/
Asav (04-28-22)
Old 04-26-22, 07:49 PM
Knucklebus
Knucklebus's Avatar
Unless you are running propane, E85 or some other fuel that burns more completely than gasoline, there will be carbon on the pistons and spark plugs. You are half way to creating man-made diamonds, aka, carbon, heat and pressure.
If the car had no symptoms and was not throwing any trouble codes, you did suggested preventative maintenance but I 100% doubt you experienced anything but the placebo effect. Butt dynos are not evidence of improvement. At a minimum, you would need before and after 0-60 or quarter mile times to verify any real world improvement.
The following 4 users liked this post by Knucklebus:
bclexus (04-27-22), Im2bz2p345 (05-01-22), JDR76 (04-27-22), NJLEXES (04-27-22)
Old 04-27-22, 01:33 PM
JeffKeryk
JeffKeryk's Avatar
Or improved gas mileage.... I pay almost $6 per gallon. So there's that.
Well done on the tune up service.
Old 04-27-22, 01:41 PM
jgscott
jgscott's Avatar
When doing a tune up service is bad, and carbon build up is good. OK. Not my ride. Drive it like you stole it! Not own it. lol!
JeffKeryk (04-28-22)
Old 04-28-22, 11:21 AM
Renrutjw
Renrutjw's Avatar
Bone stock 2013 GS 124k miles, nothing but oil and air filter changes. Filled up on Monday and soft pedaled it to work on I-95, took this pic in the parking garage. I wonder how much better I could do with new spark plugs?
Old 04-28-22, 11:50 AM
Knucklebus
Knucklebus's Avatar
None!
New plugs might help with an all-out drag race but not on an MPG run if it isn't throwing codes. I've had other cars throw miss codes when you didn't even notice it.
Renrutjw (04-28-22)
Old 04-28-22, 02:16 PM
jgscott
jgscott's Avatar
That's great, I can hit 36 also. Its been my max. How long have you had you GS? Was it serviced at Lexus?
Old 04-28-22, 06:12 PM
bclexus
bclexus's Avatar
None at all - ZERO! You'd be better served lightening the load by visiting the restroom before traveling to work. Or monitoring the wind direction for a hopeful tailwind.
Renrutjw (04-29-22)
Old 04-29-22, 11:14 PM
ViperTim
ViperTim's Avatar
Are those regular copper plugs?
My GS250 “requires” iridium plugs.
Changed plugs at only 90k km as the service manual says and they were clean. Used but clean, replaced with Iridium plugs of course.
Edit: Nevermind, I looked again and it says Iridium on them and they look like mine did.
Quick Reply: Spark Plug Change and Cylinder Head Images On High Mileage GS
