Washer Fluid Leak
Washer Fluid Leak
2013 GS 350 F Sport
Hi all, I'm having an issue where the windscreen washer fluid is leaking out. I initially thought I must have hit something underneath the car to cause the leak but I recently heard of someone who had the same issue but it was something to do with the headlight washer mechanism.
Has anyone else experienced this? What is the solution?
Sorry if this has already been covered.
Any advice appreciated. Thanks
Thanks.
There is no problem with the sensor because it goes away when I fill it back up, until it drains out again.
I will probably just get the windshield washer reservoir tank replaced. Should be relatively inexpensive, fingers crossed.
2013 GS 350 F Sport
[Edit: I don't think F-Sport models have the headlight spray feature...]
I'll be sure now to mention to the tech to check the spray line hose before ordering a new windshield washer reservoir tank.
Thanks again
bclexus (05-14-22)
