Bigger wheels/tires on 2013 AWD?
Does anyone know if you can put 19 or 20 inch wheels on a 2013 AWD? The current setup is 235/45/18s all around. I would keep the same width and side wall with just the wheel being an inch or two bigger. Thanks.
You can start with this thread to see what members have done:
https://www.clublexus.com/forums/gs-...el-thread.html
Here are a few members with AWD and a 20" wheel setup:
https://www.clublexus.com/forums/gs-...l#post10120364
https://www.clublexus.com/forums/gs-...l#post10496466
SC300Es (05-26-22)
@jeverett72 you can certainly put 19's or 20's on your '2013 AWD. Stock AWD F-sport wheels are 19x8 sitting on 235/40 tires all around. Keep in mind that every inch you go up in diameter, the sidewall of your tire should be thinner to accommodate the change in height...potentially leading to a more jarring ride. From my experience, the GS seems to ride most comfortably on 18s or 19s with a touring tire (e.g. Pirelli Cinturato All Season Plus 3).
StealthAWD
05-24-07 08:11 PM
