Lexus GS Frameless Rearview Mirror Upgrade
#31
robm (07-28-22)
#35
Thanks.
That's why I didn't rush and wanted to plan it out to look factory still. Looks like you have a Radar or Cam mount up there or connect wire? I have a Val 1 radar mount I have to reinstall with mine also. Can't wait to replace that big plastic surround mirror out.
#36
Thanks.
#37
I was more interested in seeing if my wiring was correct, also didn't realize till afterwards. I have a blackvue dash cam behind the rear view mirror, mounted to the mirror stem. It's easy to take the mirror off. The plastic panel with the map light is just clipped in and only one plug and one screw for the mirror.
Im2bz2p345 (06-23-22)
#38
I have the same problem with the wiring showing, but it not all that bad. I have switched out mirrors on cars before. Here is what mine came out like including a Radar Detector mount. Sorry about the window heat shield. I'm going to measure and get one of these so it will look 100% and hide the wires. Everything works perfect and very nice upgraded look!!
https://www.amazon.com/Mirror-Toyota.../dp/B00Z8WI49Y
I bought myself some 22 gauge wire and some wire sleeving tape to make a nice clean oem looking harness without a exposed bulge.
I found this seller on eBay that sells the Gentex covers in all different sizes:
https://www.ebay.com/sch/sincecloud/...75.m3561.l2562
#39
After 5 years of owning the car I'm still discovering OEM options to retrofit into my 2013 GS. Updated rear view mirror, aluminum door handles, ect are not things Lexus discloses on any list of model year changes. I'm sure there are other small bits that were changed that make a difference I haven't discovered yet.
#41
Just wondering why the existing cover doesnt work, arent you using the existing connector (that was transferred from the old mirror to new mirror), so the amount of space it takes should be the same?
#42
Early models had optional driving assist. Vehicles without the driving assist did not have a cover. Later years have standard driving assist has the cover and the connector for the rear view mirror reside in the cover. This is why earlier years, like the 13-14, we had to extend the wires.
#43
#45
I finally was able to get a rearview mirror from a 2016 GS200t and did the install. I noticed that the side mirrors did not dim but maybe it wasnt dark enough outside for me to notice? Was sideview dimming mirrors standard on all GS's?
