Tremendous Brake Squeal on New Breaks
after 3 month most shop would say why dont you bring it right away and why bring it back after 3 month? im a tech and thats what I would say, no1 gonna wait 3 month if you hear noises after a job. for example u did a oil change and u c oil dipping will you drive the car for 3 month with the oil dipping and then go bak to the shop in 3 month and say ur engine knocking.
Unfortunately, the above post is a representation of how customer service has devolved and I do as much work as I can myself. I completed an alignment adjustment on my wife's car this morning to avoid dealing with the shops and above techs and "advisors".
I believed him at the time only because I Googled "Brake Squeal new rotors" and read: https://autochimps.com/brakes-squeak...being-replaced
"One of the most common reasons that new brakes squeal is that there's moisture on the rotors. When they get wet, a thin layer of rust will develop on the surface. When the pads come into contact with the rotors, these particles get embedded into them, creating a squealing sound."
Richard, the type of tech who never admits fault.
Anyways, I've contacted my friend who originally recommended the mechanic (I've used this mechanic previously for oil changes and an oxygen sensor replacement). My friend had his brakes done recently as well and they also sequel. It appears that this mechanic doesn't lube anything and that may be part of the problem. I've since concluded that if I go back, he wont rectify the situation for free, so I will use a different mechanic going forward.
Last edited by badman5; 07-06-22 at 02:32 PM. Reason: spelling and added more details.
Gillie76
Suspension and Brakes
18
11-05-17 04:50 AM
is250gurl
09-07-07 09:09 AM
