Front Brake Squeal/Squeak - New Design Front Shim Kit
If anyone with a 4GS has front brake squeal/squeak noise from the front brake pads (must be either an AWD F Sport or a Non-F Sport model) you might want to check out this L-SB and consider possibly replacing the OE Front Shim Kit with the newly designed Front Shim Kit in an effort to stop the squeal/squeak from the front brake pads.
Note: The vehicle must be either an AWD F Sport or a Non-F Sport model.
Introduction: Some 2013 – 2020 model year Lexus AWD F Sport and non-F Sport model vehicles may exhibit a squeal/squeak noise from the front brake pads.
For customers who find this characteristic objectionable, an updated shim kit is now available as a service part.
Brake Squeal/Squeak (AWD F Sport and Non-F Sport)
PREVIOUS PART NUMBER: 04945-30370
NEW PART NUMBER: 04945-30360
PART NAME:SHIM KIT, ANTI SQUEAL, FRONT
► See attachment below for: L-SB-0034-18 (Updated March 10, 2020 Rev 1)
AJLex19 (08-07-22)
I had a squeal that was resolved by adding a quality lube to the back of the pads shims and all hardware but its cheap enough to go with new shims when doing a refresh.
I have a very slight, almost inaudible, squeal coming from the front brakes when in reverse with light brake pressure applied. It lasts only one or two seconds or 4-5 feet of travel. I just started hearing it when backing out of the garage a couple months ago.
I figured the cause was likely related to the Lexus issued Technical Service Information Bulletin L-SB-0034-18 (pdf is attachment of first post in this thread) .
I'll be having the updated new design anti-squeal front shim kit (Part# 04945-30360) installed on my GS 450h front brakes the next time I schedule service.
Supraman18 (02-11-23)
There's some oem aversion to lube that I haven't figured out yet, possibly due to attraction of dirt and grit but I've never had an issue. I added lube and it made them silent.
When I did my new set of pads and rotors, I lubed them from the start and didn't opt for any upgraded shims but Lexus seems to like the new shims instead of lube.
IMO, any fix to a problem, even a small problem, is a welcome improvement.
My 15 AWD F Sport had terrible squealing brakes. My 19 and now my 20 are ok so far.
I randomly heard a very slight little squeal sometimes when in reverse backing up very slowly (creeping speed like when backing out of a garage) and lightly applying the brakes. This was caused by poor brake pad contact. It was actually something I could easily overlook and just ignore but since Lexus issued a TSB and new updated part as a remedy I figured I'd go ahead and have the updated shim kits installed.
I had the TSB new updated front brake shim kits (New Part Number 04945-30360)installed today under warranty. No more slight squeal when backing up slowly...
Just need clarification. Does this shim kit upgrade apply to 2013 GS350 AWD, not F Sport, and are the last three digits 370 or 360 for upgraded shims? Or...am I reading the TSB entirely wrong and this only for F Sport and there is no updated shim kit for 2013 Lexus GS350 non F sport?
If your GS 350 is an AWD model, this is for your car!
The new (upgraded) anti-squeal front shim kit part number is: 04945-30360
Hope that clarifies it for you...
Great and thanks for clarification. Front brake pads only have 30K miles and are in good shape but I suspect that when mechanic did the job, either did not use the correct shims or did not grease or maybe both. Point is that getting tired of getting that screeching from front on cold start up. Embarrassing and annoying to say least. Made an appointment with another mechanic, first mechanic in state that we no longer live in, to inspect and grease shims. Am I assuming correctly that the pads will have to removed to grease the shims? If that is the case, OK to reinstall same pads given mileage? Both retired now and Lexus is second car and in fact only put 2K miles on it last year.
Thanks. Squeals backing out for sure but also when going forward and coming to stop on first application of brakes. Appreciate your help. Goes in the shop on Monday.
