mirrors dimming feature doesnt work at all...
Hi everyone i first let me say i have read several topics over the forum + i have done the flash light test on all of my mirrors.
My car is to the max specs all of my 3 mirrors should dim, auto dim, but only the center mirror inside the car works it have auto on and off and it works.
For my left and right mirrors i also have auto/ on and off but it doesnt change anything i tried tested with flashlight test nothing happens.... i have blind spot monitoring which works fortunately... is there a way to check this dimming feature with tech stream , or is it possible my glasses to be replaced and to have non dimmed glass?
Any suggestions are welcome or to have something broken ? Can this system be turned off from tech stream on or off or a way status to be checked ?
I am sad that my tpms cant be fixed for now but with this extra auto dimming feature i feel my car close to my classical ones...
i have driven many cars with dimming mirrors like Jaguar etcs so i know how they work, if they see light from cars they dim, so my only center mirror works and i am very sad i want to fix left and right mirrors, somehow... not sure how the system is implemented into the gs450h i dont think its related to night vision system or something else?
How i can fix them or find out if its a tech stream issue ,is this common issue, how the auto dim works, is there other place or only the middle mirror which controls left and right mirrors dimming feature?
Bladest, you have alot of bad luck with that car.
I don't even know if you have auto dimming mirrors, I don't know if my cars has them either and I don't care.
You shouldn't concern yourself with these little problems because you have some big ones to take care of first, if you ever get all these problems you say you have fixed you will end up not knowing what to do with yourself.
Just get tinted windows and that should help with the glare in the mirrors.
Wait, let me guess... nobody does window tinting in BG.
my car have all possible options including extremely rare night vision, so according to my specs and broshure i have auto dimming mirrors,
the only options i am missing are sun and moon roof and auto high beam assist. So i am always inside 18 way driver seat adjustble seat cooled and heated inside my ultra luxury cocoon.i have eyes issues so i dont see well in the dark my classical cars have standart mirrors thats why i opted to have every single possible option and i need to fix this one since i drive in the dark , when there is not a much traffic.
This is what i have from my specs sheet .
Outside rear view mirror Auto, ec, dp: aspherical, heater, bsm
- So i have auto, dimming mirror,ashperical,heated + blind spot
EC mirrors are dimmer mirrors made with electrochromic (EC) materials.
So i have it but for some strange or unknown reason to me ,both of my mirrors doesnt work at all only center one works as electrochromic i need to solve this puzzle.
My blind spot works fine on my both mirrors.
My Car have factory tinted rear windows , remember i got all the specs including water repellent ,remember the highest possible lexus ever existed and created gs baby.
I think all 3 of my mirrors dims when there's a bright light shining at it from behind me. But then I have tinted windows all around so it probably absorbs some of the glare.
When i manually flash with bright light my mirrors in the dark left doesnt respond, on started car , right doesnt change/respond
only the center mirror respond,
my rear window is tinted but my middle mirror always goes dark when there is light, but for my outside left and right thats not the case they never change ... so they are either broken or broken connections or something else like permanently disabled, is there a function somewhere else exept central mirror for this option?
I think it turns on with the middle mirror. If both left and right don't dim then maybe ur car doesn't have it.
I bet previous owner have done something, is it possible that my mirror glass is replaced, how i can verify if its genuine or not ? Are there any marking or the only option is to be dissambled, is it easy to dissamble mirrors , my car had the options from the factory but they are either damaged/ broken or replaced with non dimmable.... if the mirror have that electrochromatic option but someone replace it with regular glass with blind spot and heated only, will it work or?
My car lexus specs sheet doesnt lie i have but it it doesnt work like some of my car options....
Is the heated function working? U can pop off the mirrors and check if they're OEM or aftermarket.
Also how to start this heating function, for the mirrors, is it from the physical button or some menu inside my air conditioner? I will try to test them soon.
I think it turns on with the rear window defroster button.
