Anyone have a K&N engine filter and do they improve anything?
My GN was nearly stock. It had a slightly bigger turbo, 12psi boost, a mild chip that locked up the converter and kept it locked. Back in the day, they hunted something fierce, in and out. Best it ever ran was 13.85 in the quarter on street tires. Funny, it got about the same mileage as the Lexus GS 350.
Some of the boys can stand them on the back bumper, though. The turbo looks like it is big enough to have been on the space shuttle and it was facing forward through the bumper with no filter, K&N or otherwise.
We often talk about engine oil; its color and whether it needs replacing. Turbocharged gasoline engines will darken engine oil very fast. Not only is the turbo and the turbo bearings hard on the engine oil, but the increased chamber pressures and blow-by will darken the engine oil. Much of the additive package in engine oils tend to darken quickly from just the 100°C (212°F) typical operating heat. That darkened or black color of the engine oil often needlessly concerns many vehicle owners. But just because the engine oil looks dark or pitch black does not mean it's worn-out or in any way the least bit ineffective and needs replacing...
GibbsLexus (08-13-22)
Those that have them, take it out, hold it up to a light, and take a look at how many holes they've developed in the gauze letting dirt and nonsense through.
I'd say 80% of every K&N I pulled out of customers cars when I worked in a quick lube (For chevrolet) they were full of holes. I'd recommend a filter, then the car's owner would come out and nag about all sort of fun blah blah and airflow and nascar and what-not.
Then they'd buy a real air filter and watch me install it when I showed them their filter was more like a screen.
DON'T. BUY. ONE.
If you're down with rebuilding the motor to go to the strip and knock a tenth or so off your time then, sure, get yourself one so you can suck more air. If you're not... then K&N is going to disappoint you.
Edit: Gauze, stupid autocorrect
DON'T. BUY. ONE.
Those that have them, take it out, hold it up to a light, and take a look at how many holes they've developed in the gauge letting dirt and nonsense through.
DON'T. BUY. ONE.
DON'T. BUY. ONE.
Just nonsense. To sell customers a new filter that should just be cleaned and re-oiled. Even if you did not clean and oil it which is not proper and then it becomes user error.
Just a warning - if someone is about to show some out the car test it will be debunked and a embarrassment to test outside the engine air housing with inaccurate data. lol!
https://www.youtube.com/watch?v=7D9lJxQ1s-U
I've seen tons of them with holes in them where airflow through the filter would've been at it's highest velocity.
Save it. The proof in the pudding is how it tastes.
I hear someone recommending to sell a new filter.
https://www.ncconsumer.org/news-arti...-mechanic.html
I see nothing but inaccurate claims. I see NO proof. I see Nothing to save.
Do a little research yourself. 10sec of googling and you can find plenty of K&N filters with holes in them. Here's an example: https://www.jeepforum.com/threads/ho...ilters.729910/
I'm not going to spoon feed you, its super simple to find for yourself.
I'm done here anyways. I've seen hundreds full of holes and plenty of people like you with the same rhetoric that they're super-duper special... until you actually look at them against a light.
Everyone else that has one, pull it out and look at it against the sun or your kitchen light or whatever, you'll see what I mean.
Best of luck #haveablessedday!
Oh yeah man you're totes so right there's no way people post about this on other forums talking about it must be bull because I didn't post a link
I have one and 2 of my friends have them also. I'll ask them to post pics also. Then when No holes, then what?
Blessings to you also. Thanks.
I wonder if the F Sport one will cause any problems. If it's trash then Toyota wouldn't make it right?
PM22 (08-23-22)
It does have a cleaning solution and it is a dry filter. This is one of the reasons why I chose this over the K&N. Don't like dealing with the oil stuff. Plus it has the FSport logo, it looks cool, and it's made by Lexus so no warranty issues. Who wouldn't want that?!
