Wiper insert blades replacement
Old 09-07-22, 05:20 AM
Nalod
Nalod's Avatar
Factory lasted 2.5 years. I tossed them. Now I regret. I’ll by factory again and inserts going forward.
Old 09-08-22, 06:04 PM
sierranglr
8th Gear
sierranglr's Avatar
Got this set of inserts from Amazon. At the time they were 2 pairs (4 total) for $10. Currently $11. Over 1 year and still good but hasn't rained much in So Cal.
Amazon.com: X AUTOHAUX 4pcs 450mm 650mm 17.5" 25.5" 8x10mm 3 Section Car Windshield Wiper Blade Refill : Automotive Amazon.com: X AUTOHAUX 4pcs 450mm 650mm 17.5" 25.5" 8x10mm 3 Section Car Windshield Wiper Blade Refill : Automotive
Old 11-08-22, 02:00 AM
909's Avatar
Just picked up a pair of Bosch again . Pricey but worth it.
Last pair going on 4+ years ... and still going strong.
Old 11-09-22, 04:38 AM
maclem8223
maclem8223's Avatar
Originally Posted by ItzFilyO
Skip those nonsense aftermarket stuff and go with OEM rubbers. For some reason aftermarket blades don't work as well as the OEMs on the GS glass. I had BOSCH Icons before on my 2014 GS and they were horrible in the rain, always skipping and made a lot of noise but looked good though.
U can order the OEM rubbers at a Toyota dealer too and only takes 1 mins to swap the rubber inserts. Keep the stock blade/arms cause they're really expensive.
Driver: 85214-02340
Passenger: 85214-0E130
Completely opposite experience over here. The Icons do really well for me. Never had an issue with noise, skipping, etc. And that's on three different vehicles including the GS
Old 11-09-22, 07:33 AM
ItzFilyO
ItzFilyO's Avatar
Received 1,047 Likes on 662 Posts
That was back in 2016. Maybe Bosch changed something and fixed it. They're too pricey while the OEM rubber works great and cheap. Now that I park indoors, these will probably last 20 years.
Old 11-15-22, 09:25 AM
emazens
4th Gear
emazens's Avatar
how does the oem rubber hold up vs bosh in harsh winter condition ( heavy snow , ice , -35 / -45 C temperature ) any feed back ?
Old 11-15-22, 07:45 PM
909's Avatar
Old 02-11-24, 10:26 PM
jms123
jms123's Avatar
I know this is somewhat an old thread but I am a spaz getting the refills out and will likely be more so getting them back in especially with the wires.
After the original blades, I've used a pair that a Toyota dealer installed but I think they used after market, then I tried RainX. Both stuttered a bit. OEM blades are costing about $18.50 now a piece shipped and refills about $7 a piece so for $11-12 I don't have to fool with the refills. Kind of a waste of money and bad for environment but I know Id be fiddling a bit.
85222-30650
85212-30480
https://parts.lexusoforland.com/p/63...212-30480.html
Old 02-12-24, 02:38 PM
gripau1
gripau1's Avatar
85222-30650
85212-30480
In Australia the OEM rubber refill are $40.00AUD ($30.00 USD) a pair, yeah its a rip off but I found they work very well in my driving environment. The OE is smooth and quiet. I always change refills blades once a year. The trick to have smooth wiper operation I found is to clay bar or clay towel the windscreen every 4-6 months. This removes the traffic film and invisible stuck on contaminates.
Neophyte2b
06-20-22 04:36 PM
vs1979
GX - 1st Gen (2003-2009)
13
12-04-14 10:21 AM
TUNG
02-06-12 11:23 AM
LS430inDE.
12-03-09 07:44 PM
TommyT
06-19-08 07:20 PM
Quick Reply: Wiper insert blades replacement
