Brake Fluid Color
Brake Fluid Color
Is there any chance the below is 2 month old brake fluid? I had some suspension work done at a new shop and while I typically flush my own fluid, I figured I'd give them the business while the car was in the shop. A month ago I did brake pads and rotors and when I pulled some fluid out of the master cylinder, it was a dark color like the below. I was expecting a clear color due to the recent fluid change.
Any fluid I have used in the past was a nearly clear color with a light gold tint however I know there are fluids such as ATE Super blue that are tinted on purpose to help identify the new fluid during an exchange. The below just looks like old fluid that they never changed.
That's what I pulled from the rears using a MityVac hand vacuum pump and replaced with the OEM Toyota DOT 3 which is the typical clear color.
I don't think there's an underlying issue that would cause the fluid to turn that color in a couple months, just checking to see if anyone agrees that the shop didn't do anything and charged me for it. I didn't notice much of an improvement in pedal feel afterwards whereas just from the rears that I did myself, I can feel it already. I'll get to the fronts in the next couple days.
That 100% looks like aged fluid to me. Like, several years and thousands of miles kind of aged. My wife's '18 SUV has clearer fluid than that with 60-ish kmi
My truck has cleaner fluid than that. And the fluid is 3yrs old by now.
Like BMGS, I'm accustomed to almost clear brake fluid when new, maybe with a slight yellow tint, and a dark color is usually associated with very old and/or contaminated fluid. Might be a good idea, if only to satisfy your curiousity, to get a fluid tester.
Now I'm considering a brake fluid flush and replace since it's been 4 years from new.
Edit: Just saw this vid and placed the tester in my Amazon cart.
https://youtu.be/SHMpxXGkXzw
The MityVac was much easier than the Motive Pressure bleeder I used in the past, I'm glad I made the switch.
93SCMax (09-26-22)
Yup much better now per the photo below. I saw that the color was darker but assumed it had to due with the plastic of the reservoir, I assume the shop wasn't scamming me but good to know there are still crappy shops like that still out there.
The only downside is that the vacuum introduces bubbles into the stream post bleeder so its not the best tool for finding every little air bubble in the fluid. Perhaps a tighter tube would help that but I figure if I run a few cycles and about half a jar of fluid per caliper, I've done all that I can. The Motive bleeder was better for that but still there are more positives to the MityVac and too many negatives with the Motive.
93SCMax (09-26-22)
