Sad Night Last Night
I would have to run it up but if I remember correctly its 2006 - 2012. I know the after Market Headers are compatible all across. The 2016 plus difference are only compat with the newer 2GR 16+. One would need to cross ref but they do work.
https://www.ebay.com/itm/18560552047...8aAuimEALw_wcB
In years past I'd agree, I'm at the point now that it was either pay a ton for an LS (I cant right now) or get an IS and that's too small for me. I can do some work for the ES and make it my own which I plan on doing. Its comfortable, has a smooth ride and they redid the entertainment system which might seem like a small thing but for me, it was a selling point over the old style which needed an update..and badly.
Curious to see what the OP says but from my perspective its easy to scoff when I receive a letter in the mail with an ES offer but its another thing when your 123K mile car is sitting on a lift with a recurring issue and then you sit in a brand new car with an dangling offer. Its not a GS but still is a really nice looking Lexus!
ES is fine if u just need it for commuting. Just keep it under 100, it can get sketchy over 100 especially if it doesn't have AVS like mine. U can always trade it in for an LS later when u get tired of it, ES has good resale value I think.
And keep an eye on that FSport emblem on the steering wheel, the adhesive seems to get loose after a while and can fall off. Happens to many on here too it seems, including mine. Never had this issue with the GS.
greys0uled (10-07-22)
The 4GS has two cats correct? How much did it cost to replace the first time, and what did they quote you the second?
I was gonna say that I feel like you gave up on the car too easily. But if this is a bigger issue and they can't diagnose it correctly then I understand moving on.
Congrats to OP on the new ride.
Mileage matters for a number of reasons, as I've personally learned.
- Not everyone is a DIYer. Many have busy lives and don't have time to be junkyard-hopping and DIY'ing/Wrenching on weekends for hours at a time. Things like cats or balljoints are a big no for those who are time-constrained.
- Things wear out. Sure you may replace oil, brake pads here and there, or your cabin filter. But certain items that are hidden/hard to reached/or generally inaccessible by your home-gamer will experience wear and the car just gets weaker and more bendy/loose/loud over time. Plastic and rubbers dry rot, seals wear, brake lines harden, and things get brittle and rot. On an aging car you can suddenly find yourself playing "whack-a-mole" as various things age/wear/dry/deteriorate--things that aren't reasonably DIY'd or accessible either with time or money. And even if certain items are accessible or DIY friendly, they can be expensive/hard to find. Think door seals/door aperture seals/window seals that dry rot over time on aging cars--they tend to be super expensive.
- Chassis gets weak as it ages and goes through hundreds of driving cycles bending, flexing, stretching, compressing, twisting, etc-- welds pop (under the paint) etc. You don't realize it cause you get used to it.
- Things like subframe bushings, differential bushings, balljoints will almost certainly never get changed and if and when they do, it costs a lot of time and money.
- Things like paint and rubbers/plastics need constant upkeep and refreshing. True of any car, sure. But on older cars, options get limited as paint thins out after washing/waxing/cleaning/corrections.
- The list goes on and on. Engine/powertrain, clutch, flywheel, rear main seals, wheel bearings--things that can become a PITA time/cost wise. I've experienced all the above!
I waved goodbye to my GS last night. It was only a year and a half ago that I had to change a catalytic converter on it. After I got it fixed it ran beautifully. Fast forward to about a week ago and the engine light came on. I ran the diagnostic and came to find the other one was now bad. I took it to Lexus to confirm and while there they had me take a look at the new ES F Sport. After a test drive and them making me an offer on my broken GS, I drove off in the ES. Besides the convertor issue, the GS was one of the best cars I've ever owned. I was a bit sad to see it roll away.
My New Ride:
My New Ride:
can you tell me,
how much they valued your gs and what year was and how many miles and what level of equipment ?do u way 18 way seat adjustment or ?
Mine gs 450h have 4 cats and car is 200.000miles and not yet replaced working like charm.
i also have 2 classic car 30-40 years old i drive on a daily base with these stretched chasis and other things someone mentioned above great cars!
So thats not true.
if you have reliable car it will last really really long time, its true i made some maintenance this year i replaced air conditioner radiator other one was shot, and brake disks and pads... for front and oil and filters...
The ES is a fine car. Congrats.
I would use good fuel this time always and make sure as BMGS says, run some cleaner in it periodically. For those who have this problem there are aftermarket Cats much cheaper and/or you can buy some off of someone who put Headers on their car with low miles. Like me. Also the GS,RC, IS, are all the same Exhaust Cat fit.
maclem8223 (10-07-22)
Hello congratulation of your new car, but gs is way better compared to es,
can you tell me,
So thats not true.
can you tell me,
So thats not true.
if they had a new gs i probably would have gotten that but as you know that’s no longer an option. The LS isn’t in my range and the IS was s a little to small for my families needs.
I got the 2015 GS with 30 miles on it and just went over 123k. They gave me 19k and I wasn’t willing to buy an older car. So for my needs it’s just right.
I look forward to modding it, it should be a good challenge. It’s definitely not the ES’s I recall from my teen years. (I’m in my 30’s)
