Brake fluid/Coolant replacement - how much needed? ?
My rig is a 2013 RWD F Sport 80K miles. Talked to original owner still has the original brake fluid/coolant/transmission fluid/differential fluid. Taking to a mechanic for tranny/diff but going to do brakes/coolant myself.
Going to do a brake fluid change using mityvac tool and a partial coolant change (draining reservoir and radiator only). Not a mechanic by any means but feel I can manage it thanks to Toyota Care Nut and DIY Dan videos on youtube.
How much of each fluid do I need to refill properly?
Any tips from experts appreciated as well.
Thanks
Thanks
gs350noob (10-14-22)
There's no set amount of brake fluid. You flush until the fluid is clear and free of bubbles at each corner, I suggest getting 1qt.
Better if you have techstream to flush the ABS too.
lazybummm
GX - 1st Gen (2003-2009)
09-13-17 10:03 AM
Bumbobee
06-30-09 05:18 PM
