Lowering springs journey
Old 11-08-22, 03:01 PM
fourgs
fourgs's Avatar
Default Lowering springs journey
So its a 2017 f awd.
got rsr down springs.
installed only the fronts and kept it like that for a couple of months. Ride was nice luxurious and sporty the front was good in the turn. All perfect with the ride. And the rsr front springs are exactly the same stiffness over bumps like rear oem, maybe even a little bit softer than rear oems. They are 5k (kg/mm)
then I decided to also install the rear ones for an even drop. They are 8.6 k. For me that was a mistake. They are way too stiff and it lost the comfortable ride. Now I put the stock ones in the back and happy with the ride.
Old 11-08-22, 11:52 PM
BMGS
BMGS's Avatar
Perhaps you can try Swift in the rear if the rake is too much. They feel great on my setup. The only problem is that they come in a set of 4.
Old 11-09-22, 03:33 AM
IntrinoX
IntrinoX's Avatar
Sounds like you’d want a softer spring rate for the rear!
Old 11-09-22, 06:05 PM
GrandSedanFan
GrandSedanFan's Avatar
Do you have any pictures of the car dropped on RSR down front only?
I am still trying to figure out what I want to do with my car. Given a big budget, I'd do RSR coilovers with Down rear springs, as the RSR dampers are designed to work with those rates. I get the distinct feeling that the RSR rear spring, while great for handling and neutralizing the heavy understeer in our cars, is too stiff for the AVS rear shocks.
Old 11-10-22, 07:10 AM
fourgs
fourgs's Avatar
Front rsr rear oem
The following 2 users liked this post by fourgs:
GrandSedanFan (11-10-22), JDR76 (11-10-22)
Old 11-10-22, 07:12 AM
fourgs
fourgs's Avatar
yes but since I didn’t see anything softer than oem ill keep oem then.
Old 11-10-22, 07:14 AM
fourgs
fourgs's Avatar
On the highway it was bouncy in normal mode and then in sport+ shocks were dampening the springs but just too stiff for what the car is. Not for me I mean.
Old 11-10-22, 07:30 AM
fourgs
fourgs's Avatar
Fronts I did myself. For the rears I went to the mechanic, couldn’t do them at home. But mechanic said he wouldn’t wanna do it again because it’s difficult especially to put the stock ones back because they are longer. Now im happy with the comfortable ride and will leave them at that
Old 11-10-22, 07:39 AM
fourgs
fourgs's Avatar
Why I did only the fronts for half a year is:
1) because the front rake looks like an suv and you can see the aluminum parts when you look at the car from the side.
2) I like quick turns and the heavy engine up in the air makes the car lean more on tall springs.
3) tires were wearing on the outside edge because of the leaning.
4) improved steering feel.
6) improved control.
5) too soft for no reason because you still feel the bump with the rear axle which is stiffer and so the peak harshness over bumps stays the same.
Old 11-10-22, 02:45 PM
jgscott
jgscott's Avatar
Received 1,358 Likes on 1,078 Posts
Just FYI: Not really suppose to mix spring rates like that. Factory rate with aftermarket rates. You run all the same matched.
Old 11-10-22, 03:19 PM
fourgs
fourgs's Avatar
Why wouldn’t I choose different rates for front and back?
For me its the best setup. Maximum handling with stock comfort. Didn’t have any issues including driving at car limits (of lateral grip).
Old 11-10-22, 07:51 PM
jgscott
jgscott's Avatar
All 4 sets of springs are matched front to back for weight distribution, based on the front rate to back rate. The aftermarkets are all different but still matched together all 4 sets. .
Why does RSR, Tanabe, Swift not sell just fronts, or just rears? Why are the IS springs both Factory or aftermarket not the same? Even the Spring changes in the GS from year to year and model to model are different. Call a Performance Suspension company and ask them about just throwing on different springs front and rear.
You can run what you want, but all 4 springs are always matched to go together. I would even go as far to say that likely on a track, you would have some adverse effects, and be worst with Factory on one end and aftermarket on the other end vs just stock. There is a lot of Geometry that goes into developing spring rates for cars. Just FYI: for drop looks is one thing. The 2013 Lexus GS350 out handled and out performed the BMW and Mercedes and others on the track stock comparisons.
Old 11-10-22, 08:41 PM
fourgs
fourgs's Avatar
Here someone posted on the forum that over the years lexus used different springs. For the AWD they changed 3 springs in the front (original 2012, stifest 2014, then 2015-2019 softest, softer than the original) but never changed the rear springs for my 2017 awd. My 2017 front was too soft so now it rides more like the original gs.
Old 11-10-22, 09:35 PM
jgscott
jgscott's Avatar
Yes Pete posted and he is very knowledgeable about our suspension. Good point, but imo the stock springs are not aftermarket lowering springs. The RSR Downs are the same for all years. I see what your saying but it's still a mix of stock with aftermarket front and rear.
Old 11-10-22, 09:53 PM
GrandSedanFan
It has been my experience that spring rates are spring rates, particularly when linear. There is no issue mixing and matching to meet your specific needs.
Quick Reply: Lowering springs journey
