Engine sounds
10th Gear
Engine sounds
I am a new Lexus owner(2013 Lexus GS350 with around 152,000 miles) and I've been going through the forums and there seems to be others with similar issues.
The issues I'm having are a whining sound as I'm going down the road and I'm increasing my speed and it is going through the gear changes which was referenced here: Engine Whine (see Jjmuckley's clip).
The second issue is a loud startup(that has been posted about before on here and most have said its just the direct injection sound but this is pretty loud. It almost sounds like a diesel engine. Others have labeled it as a clatter sound. And when I recorded it I will say its hard to even hear it over the normal engine sound.
Reference 2017 GS350 AWD engine clatter noise during cold morning startup (reference the video posted by Umar22079 as I am hearing the same sound).
I'm really looking to get some answers as I just spent over $1000 on repairs and I'm trying to avoid another $1000 repair bill. If it's not serious then I won't worry but if its something I would need to get checked out then I'll do so. I just don't want to go to the mechanic over something that's a "normal sound".
Sorry if the "does this sound normal" topic gets posted a lot.
But who else can I ask but you guys!!
Here are my clips:
Here are my clips:
Also have a '13 GS350. Sounds about the same including the squeaky brakes when cold... Engine cover does muffle the direct injection sounds somewhat. Also I understand that there is a kit to to quiet one of the engine components in area where you you highlighted. There also was a recall or TSB some years back that addressed a whining sound around 50-60 mph.
Seminoles2 (11-28-22)
I made a thread a while ago about plastic covers with foam insulation for the high pressure fuel pump in the engine bay. This makes a minor noticeable decrease to the sewing machine noise, the covers are from the LS but fit the non-hybrid GS.
https://www.clublexus.com/forums/gs-4th-gen-2013-2020/876830-engine-fuel-pump-noise-reduction.html?ispreloading=1
10th Gear
https://www.clublexus.com/forums/gs-...ispreloading=1
10th Gear
tompass (11-29-22)
One noise that I can likely confirm that it's NOT is the the issue with the vacuum pump. I'm don't seem to hear that in the videos at all. I went through a lot of discussions about noise and videos with the different noises to try to figure out what my noise was. Once I nailed it down, found some documentation about it, I was able to get it repaired at no cost.
I definitely hear the high pressure fuel pump noise (sounds sorta like a sewing machine). Other than what I assume is the brake noise folks are talking about, it sounds pretty normal to me.
The hood and the engine cover makes a huge difference in terms of the amount of noise.
Seminoles2 (11-30-22)
Here are my clips:
2013 Lexus GS350 cold startup.
Reverse from cold startup - not sure why the brakes squeak like that(only on cold startup)
Engine Rev up and down to idle.
Here are my clips:
Here are my clips:
Here are my clips:
Also I moved from TX to NM and my brakes make that squeaky sound when they are cold. So all three are perfectly normal.
Since I bought mine in July 2021 I've put approximately 10k miles on it and taken two long road trips and have had no problems whatsoever.
This is what my engine sounds like (you can't really hear the clattering sound in this clip but mine has it)
https://drive.google.com/file/d/1Knq...6Tt-vaZlp/view
jaishanker
07-31-18 11:10 AM
UpSideDown
12-14-15 06:51 PM
