how to fix carbon deposit build up on 4th gen gs 450h?
#31
OP, most effective way to remove any current carbon buildup is to remove the heads to clean the chambers and valves. To prevent further buildup, use quality gas and/or fuel cleaners like Techron. The most effective measure is installing the aforementioned oil catch can.
Edit note: you could use a borescope to view current carbon buildup. But not much you can do about it … short of removing the heads. Chris Fix did have some success with on the shelf chemicals.
#32
2ndgenwin
04-11-21 09:11 AM
TerryTCL
01-21-03 08:29 PM
