how to fix carbon deposit build up on 4th gen gs 450h?
Hi i want to ask , how to clean carbon deposits for gs 4 th gen 450h ,is it a big issue what will happen i will not have peak power etcs? How complex is to clean this carbon build up how i can prevent it do i need to use additives or ?
How big is this carbon deposit build up as an issue for gs450h 4th gen , since car is direct injection.
LeX2K (12-03-22)
It's not a problem on these engines. Unless your mechanic has diagnosed it as a problem due to symptoms you've reported, do not concern yourself.
If you need to get the valves cleaned, you'll just have to book in and wait until your village mechanic has time. What else are you going to do but wait? If you have to ask, it's well over your head and not something you will DIY.
Yeah I don't think it's a problem for the 4GS line but we'll make an exception for u!
i am not mechanic like you so i have no clue , simply because of the injection technology i think.
Again well documented over internet.... all direct injection systems cars build over time carbon deposit.
i am pressure sure that over time car builds carbon deposits some people with lexus LS - which is also direct and port injection have also same issue carbon deposit and they need to clean car not sure how often.
