Steering wheel movement for easy entry.
Sorry if this has been asked before, but this has really been bothering me lately. The steering wheel, it automatically tilts out of the way and also moves to the dash to allow "easy entry/exit" to the car.
Is there a way to customize this in Techstream or otherwise? I'm a taller guy, and I like my seat a certain way. It's annoying how I have to get out of car. Further I cannot store anything in the back seat or have colleagues in the back seat of the easy entry is on for the seat (working on this though through carista's beta version of their app).
I wouldn't mind the steering wheel going up/down, but the retraction gets in the way of my knees, so I have to twist my legs to get out, if that makes sense?
Any ideas?
Any ideas?
Yes you can eliminate both of these options with techstream. I turned both off, set a different driver position for easy exit and set it to driver 3. That way if I ever want easy exit I just press driver 3 and it goes to that position. You can also customize the seat movement to about 1/2 of what it does on full easy entry and exit. The steering column movement is on or off, can’t be reduced to less, unless like I said you create a 3rd driver customized setting and then just turn the easy exit off for both the seat and steering column. I was un able to delete/ turn off the steering column with Carista but it was available in techstream customizations.
Yeah Carista doesn't have the steering wheel one, only the seat which u can also do it from the nav system.
frankymenz (12-05-22)
I can set this inside the menus in the car.
I simply disabled the seat movement and only have the steering wheel movement.
Theres no need for any extra gadgets in order to do these settings.
At least not on my European model.
Mylex400
RC - 1st Gen (2015-present)
11-27-18 04:56 AM
Tantrix
08-19-16 08:18 PM
