GS 350 Coolant Change - Should I get 2/3 Gal?
Hello! I want to change the coolant on my GS 350. I am trying to figure out how much new coolant I need to purchase in order to fill after draining from the engine block and the radiator.
Some videos suggest I need 3 gallons to do this, but some threads suggest that a single change can only get 40-60% of the fluid out which is around 4-6 quarts.
Any suggestion? Thanks!
M
[QUOTE=ChickenNug;11405081]Hello! I want to change the coolant on my GS 350. I am trying to figure out how much new coolant I need to purchase in order to fill after draining from the engine block and the radiator.
Any suggestion? Thanks![/QU You only need 2 gallons, I did a water pump on my 2018 F Sport with 2GRFKS. I drained the block completely before removing the WP, I didn't need any more than 2 gal.
[QUOTE=Mitho1991;11405188]
What was your procedure for draining the block?
vinster29
Hybrid Technology
12-01-23 11:49 AM
