4th generation 450h gs where is lug nut wrench located ?
Hi everyone can someone show me picture where is located the lug nut wrench i so far bought jack and i got another strange item, i think its for the jack but i am not able to located the lug nut wrench where is located into the hybrid car 450h gs 4th generation into the petrol car 350 its in the rear where mark levinson amp it is for the hybrid i also have spare wheel... any picture will be welcomed.
It sits above the amp, on the right side of the boot. There should be a screwdriver for releasing the parking brake, lug nut wrench, security lug nut adaptor etc. If it's not there, just buy a 19mm socket.
Are you sure about 19mm socket, i was thinking lexus is using 21mm ? I am little bit confused.
I have floor jack and spare wheel but they are into the left side of the car close to the car battery /starter battery.... but i dont see wrench...
So the whole set of tools and tray are missing then.
Yes on the left i have floor jack and my spare is into the center on the right side i have only mark levinson amp. i have no tray i am not sure if it even hybrid cars had a tray into the right?
Can someone provide picture please since i am unable to located over the i-net for gs450h.
Go to ebay and do a search for tool kit for your model, why do you always expect others to do the work for you?
ECL (12-10-22)
https://www.ebay.com/itm/26490073261...3ABFBMiJ3CwZ5h
I will try to inspect my car tomorrow deeply and search for these instruments if i dont find them unfortunately previous owner stole them....
Can someone confirm is the wrench size 19 or 21 or other size mm?
I am not sure if GS 350 and gs450 uses same tray thats for 350 , because gs450 have big hybrid battery in the trunk + car battery in the trunk .So location of components can be different also trays but my guess only if someone is having tools for gs450 it will be great to see them .So i can be sure to check the right place i will remove all carpets in the trunk tomorrow in search for this wrench and this plastic tray.
Hopefully i will find something if not i will need to spend small fortune for plastic tray+ wrench.
Does all LEXUS cars uses same wrench size and what size is it?
The following 2 users liked this post by Cwang:
Mangsailor (12-09-22),
NJLEXES (12-09-22)
The tool kits in cars are about as useful as pockets in your underwear, just get a jack and a tire wrench.
where i live people makes nasty suprises they unscrew your wheel nuts , so i want to prevent an accident , and my garage is open , everyone can do it , i recently saw some names written into the dust close to car paint... so they makes mizery all day long. So before i start the car i need to be sure hub bolts are tight..
