Came across these and thinking of mounting them on my lex. They are originally genesis rims but (to me) resemble the gsf rims. They are 19x8.5 front 40mm offset and 19x9 rear with 49mm offset. Tires are lil bit thicker than regular gs and are 245/40/19 front and 275/35/19 rear.
what are you guys thoughts? Hub bore is 67.1 on these wheels so would need hub ring’s too.
last pic is my car then be going on
Cannot comment on any headaches you may encounter with getting them to fit though they definitely look like the GS F wheels. If you can get a good deal on a set, I think they'll look good on your modded GS.
Those look nice and remind me more of my RCF wheels with a touch of GSF. I like the design a lot on my car and the offsets may work pretty well. Looking forward to seeing them installed if you decide to pull the trigger.
Good luck every time it's time to clean all those spokes and holes. I was so glad to get rid of my stock Lux spoke wheels for that reason.
I don't have any issues, I use a soft wheel brush and a microfiber cloth to get anything the brush missed. I keep the wheels coated and give them a presoak to make the process much easier.
