Stripped Torx on Sunroof
So I was trying to replace my sunroof’s weather stripping due to the infamous rattle. The rear two Torx came off pretty easily, but the front two are held on extremely tight. So far, the two front Torx have been stripped pretty badly. Tried using an allen wrench, a T26 as a bigger head, and a rubber band over the head - no use. Any ideas on getting this screw out without damaging the assembly? It’s a really tight space so I’m not sure anything bigger than a torque wrench would get a good angle.
Do you have an angle grinder? Take a flat head screwdriver you don't like and shape it so it barely fits, hammer it on. A screw extractor kit would also work well in this situation. A hex driver might work if you happen to have one you can hammer on for a tight fit.
damantou (01-04-23)
The following 2 users liked this post by Cwang:
Im2bz2p345 (01-04-23),
thisguy_06 (01-12-23)
What's the OD of the fastener thread? You could drill the head off with whatever the OD is (are they M6?) then use a smaller left-handed drill bit to extract it without having to hammer, grind, or chisel.
Are these historically loc-tited into place or are they just pains in the rear? I need to do the weatherstrip on mine also, so I will plan ahead if this is a known issue.
Counter-torque is your friend too when dealing with torx heads like those.
In my case, the rear ones were a little tough in the beginning but once off they aren’t as tight when taking them off again. The threads didn’t have loc-tite on them. The rear has more height to work with, so if you run into trouble with them, it is much easier to get them out. I would also buy new screws just in case something happens.
https://www.lexuspartsnow.com/parts/...159-50336.html
I bought screw extractors and will try in the next few days, but I’m afraid the drill won’t fit in the front for a straight impact.
@damantou there are a few threads on doing it without removing the sunroof...I wouldn't try to mess with the torx screws especially now that they are stripped. I used a plastic pry tool to help squeeze in the new rubber into the tighter front sections with the sunroof tilted. See these additional posts/threads:
https://www.clublexus.com/forums/gs-...ml#post9958081
https://www.clublexus.com/forums/gs-...l#post10515046
The following 3 users liked this post by AJLex19:
I threw away my extractors about 8yrs ago. Every bolt I've had to pull since has been left-hand drilled, slotted and had a big flat head used, external "socket type" extractor, or a freshly sharpened pair of Knipex channel locks put on it. Oh, and make sure a quality tool is being used on anything japanese or to a DIN standard. They don't like loose tolerance stuff.
But if you can get away with not pulling the fastener out, then work around it. Chucking metal shavings in a leather interior is never ideal.
damantou (01-04-23)
Im2bz2p345 (01-07-23)
I wouldn't come anywhere close to that glass with hammer. If he stripped the torx with torx bit, imagine what outcome with hammer will be.
Why would anything else be a choice at this point at all? I did it in like 10-15. No screws removed at all.
I was able to replace the stripping without removing the Torx screws by following AJLex19's links. As the others said, the trim removal tool is very crucial in this procedure since the side pieces are going to really hard to press into space without it. I highly recommend buying the plastic ones so that it doesn't damage the stripping when pushing between the stripping and the roof. Thanks all.
Im2bz2p345 (01-09-23)
