Replaced Right Outisde Mirror - BSD Errors
Housingless mirror that still works fine.
I broke my passenger side (right) mirror housing backing into the garage on Friday the 13th. It didn't break the glass but it broke all the top part plastic. That's the painted housing, the black housing and the inner pot metal piece it all bolts to. I found a compatible one on ebay for cheap, non-OEM, that said it was heated, BSD, turn signal and puddle light. I bought it and a can of rattle can paint the proper Metro (Meteor) Blue to paint it.
It took a week to get all the things together and mask it off but I finally had a warm enough day to paint and clear it. It came out looking pretty decent except the shiny black plastic on the OEM mirror is matte black on the new mirror.
So, I have it all mounted and installed. The mirror moves, the blinker and puddle like works but when I fire the car up it immediately gives me the BSD (Blind Spot Detection) error. The light on the mirror doesn't light up like the one on the driver's side.
I emailed the manufacturer and they said it may need to be recalibrated. Lord, I hope not. The old one, despite being naked without a cover, still worked just fine. I drove it around for a few days until I got the parts in and BSD worked without issue.
Are they yanking my chain or does the BSD really have to be recalibrated after the mirror is replaced?
I wish you the best of luck finding a fix and hope you find an answer soon.
Like you I also had to replace my mirror , but lucked out by finding an OEM white one ( that looked like trash ) at a junker ( car-part.com ) that cleaned up nice with no issues.
Knucklebus (01-30-23)
Seen this problem a million times on CL. Seems our cars it's a year compatibility issue. Someone should make a DIY on it.
https://www.clublexus.com/forums/gs-...ing-light.html
https://www.clublexus.com/forums/gs-...k-anymore.html
https://www.clublexus.com/forums/gs-...lp-please.html
Now, if I can just return the spray paint that wasn't a good match.
If it's internal and no one will see it, I've had success welding plastic with a soldering iron.
https://www.youtube.com/watch?v=kibSo9JqWyo&t=78s
It's too bad it's not the driver's side , because I have a spare I don't need anymore.
At least your new mirror will look brand new with perfect paint.
Post some pics when you're done.
Looks like I'm going to return it as not as ordered and see if I can rebuild my old one. I ordered a top painted cover and black plastic surround from Bell Lexus. All I have to do is repair one of the broken arms on the mount. I think I can use those aluminum brazing rods to fix it. If not, a whole lot of JB Weld should do the trick.
Its better to have a working, repaired OEM mirror over the aftermarket headache anyway!
I think this is the route you could have gone first since most of the mirrors functions were working and the mirror itself wasn't cracked or damage. For less than $100 i'm sure your getting the OEM outer components and its factory paint matched to that awesome meteor blue color.
I'm sure returning a painted mirror is going to be another exercise is frustration but I'm going to give it a try. It isn't my fault they sold a mirror as paint-to-match with the features I checked off. I was going to swap my mirror and wiring harness into the new housing but the screwed up color makes that a non-starter.
At any rate, I'll get it done, one way or another. I've spent more and got less worse than this.
Gratuitous damage pics for your cringing pleasure.
Broken tab on internal support.
broken pieces.
Mismatched paint color, too dark.
You can buy the entire plastic housing from a Lexus dealer for less than $100, perfect paint match from the factory, don't waste your time with aftermarket crap.
Here is the driver side for sale, just contact them and ask about the passenger side in whatever color you need:
https://www.ebay.com/itm/233918085902
Knucklebus (01-31-23)
The cover arrives today. I tried JB Weld first. We will see if it holds once I start putting it back together.
Tab with JB Weld repair.
Upon closer examination, this mirror has been cracked and painted before. The place I cracked it has body filler in it and on the inside there are two cracks toward the bottom that are filled and don't appear on the outside.
I knew it had some paint work on the passenger side when I bought it but now I know why it was so fragile. At least it will be better than when I bought it.
Filler and cracks on the inside. Only the top (top right in picture) is visible on the outside.
Knucklebus (02-02-23)
