Oil change
Old 08-12-15, 12:15 PM
jhontelj
jhontelj's Avatar
Default Oil change
Does this light means it's time for a oil change?
Old 08-12-15, 12:38 PM
popping
popping's Avatar
Possibly. Depends on what you have set for your maintenance reminders. I believe it's under setup>vehicle>maintenance
Old 08-12-15, 12:48 PM
jhontelj
jhontelj's Avatar
Default Oil change
Thanks.....
Old 08-12-15, 01:27 PM
flippd
flippd's Avatar
Based on the number of miles you have, must just be the 6 month reminder. No oil change until 10K / 12 mos
Old 08-12-15, 01:40 PM
Afrosheen
Afrosheen's Avatar
Weird mileage to have that come on. I believe mine had a 5k, oil change at 10k, another checkup at 15k and another oil change at 20k.
Old 08-12-15, 02:37 PM
dchar
dchar's Avatar
The OP has a pic of his/her Trip B on and not the Odometer.
Depending on your mileage, you need to take it in for service. The major ones (oil and filter changes) are at 10K mile intervals. The 5K mile interval ones in-between can be skipped, and you'll just have to reset the light yourself.
Resetting maintenance light:
1) Odometer must be in Trip A display
2) Turn car off
3) Press and hold odo button
4) Without foot on brake, push ignition button twice (while still holding odo button)
5) Continue holding odo button for a few seconds and watch display until lines clear
6) Release odo button
Old 08-12-15, 04:01 PM
jhontelj
jhontelj's Avatar
Default Oil change
2) Turn car off
Correct I have 53k
Old 08-12-15, 04:44 PM
Received 2,751 Likes on 1,968 Posts
TThe 5K mile interval ones in-between can be skipped
If you have an AWD F Sport or a non F Sport GS, skipping the in between services will accelerate tire wear, just FYI. The point of that 5k service is to rotate the tires.
Old 08-12-15, 04:45 PM
jhontelj
jhontelj's Avatar
Default Oil change
Thanks I'll be getting them rotated this weekend
Old 08-12-15, 07:01 PM
flyingdave
flyingdave's Avatar
I've never owned a car that I ran synthetic in but are you guys really going 10K miles on an oil change??? Just bought this GS and that just sounds WAY high to me, even on full synthetic. I'm old fashioned I guess...
Old 08-12-15, 07:22 PM
Thats what Lexus recommends, 10k between oil changes.
dougm213
dougm213's Avatar
I too used to religiously change every 3K miles. First car with Synthetic and I am following the 10K rule. I suppose if I ran the car harder I might move it up to 7.5K.
Old 08-12-15, 07:34 PM
flyingdave
flyingdave's Avatar
I was a service advisor at an Acura dealer what seems like a lifetime ago and used to talk to the factory rep about oil on occasion. Oil to me has always been "cheap" compared to other problems I used to see so I just change it. Now, regular dino oil is definitely cheaper than this thing to change so my tune may change a bit.. lol. Maybe I will stretch it to 7.5K
Old 08-12-15, 07:43 PM
bclexus
bclexus's Avatar
Received 2,274 Likes on 1,620 Posts
That synthetic oil with [only] 10k miles will test about like brand new oil. Synthetic oil is good for 30k miles or more in many cases. Short trips and stop-n-go city driving is really the only reason the car manufacturers recommend 10k-15k miles. Many vehicles determine when to change the oil based on engine operating data and you'll see 12k-15k+ miles clocked before the oil needs changing.
If you think 10k miles is too long - get the used oil tested and you'll learn it's almost as good as brand new oil...even though it may 'look' like it needs changing.
Old 08-12-15, 08:05 PM
flyingdave
flyingdave's Avatar
Man. I guess things have changed with synthetics in 18 years... lol...
Thanks for the replies.
Quick Reply: Oil change
